Author Topic: Do i need an external oil cooler? 8v 155bhp  (Read 3281 times)
Offline rossbarry1
Re: Do i need an external oil cooler? 8v 155bhp
« Reply #10 on: 03 September 2011, 07:26 »
what is this advanced altererd curve to match cam? I took my tsr203 cam out because it ran so lumpy. Is there something you need to do to the ignition timing to get it better? Thanks
Offline Diamond Hell
  • Opinions я Us
« Reply #11 on: 03 September 2011, 09:20 »
Sounds like some modification to a vacuum advance unit on an early dizzi, or something.
Get mappable ignition instead (like megajolt) and once done it'll run better anyway.
Offline danny_p
« Reply #12 on: 03 September 2011, 10:12 »
erm  the 8v gti DIGI  dosent work with a vac advance dizzy   its just a pickup advance is applyed by the ecu.
would like piccys of the dizzy if it is vac advance type running on a digi ecu as thats a bit diffrent.
with a vernier to get the cam timeing spot on and maapable fuel and ignition you can get an 8 valve with a crazy cam to idel  very smoothly takes a while tho and imo uses more map sites than its worth
all the VW's have gone bar 1.
Offline rossbarry1
« Reply #13 on: 03 September 2011, 11:00 »
any idea how easy/expensive it is to set up a stand alone management and where i would start?
Offline Andy P
« Reply #14 on: 03 September 2011, 15:08 »
I fitted a vernier to my 8v. It cost me £150 to set up on the rollers. Transformed the car!!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #15 on: 03 September 2011, 15:50 »
A lot of people run megasquirt as its a DIY standalone but they are all pretty complicated or easy depending on your electrical skills
