Author Topic: Another 280mm question (have searched!)  (Read 4553 times)
Offline Mark 2 Mark
« on: 01 September 2011, 14:22 »
Ok so if I use G60 callipers and carriers, discs and pads will these fit under 15" BBS RA's? Only I've seen conflicting information. If not would spacers solve the situation and could anyone recommend these?
Thanks in advance
Offline tech1889
  • Mk2 GTI FTW !!
Re: Another 280mm question (have searched!)
« Reply #1 on: 01 September 2011, 14:35 »
If it doesn't fit then yes Spacers would solve the problem depending on how much room you have
Offline bmm
  • Be patient... I'm an idiot
« Reply #2 on: 01 September 2011, 14:53 »
Yeah, there's precious little info out there about what will/won't fit over 280mm brakes.  For what it's worth, my 15" RS's needed a 3mm spacer (from Halfords, no less) so the back of the split bolts wouldn't hit the caliper.
I reckon because your wheels won't have the bolts you'll be OK, but the only way to be sure is to give it a try and buy a small spacer if they rub anywhere...
Offline Mark 2 Mark
« Reply #3 on: 01 September 2011, 15:00 »
So safety wise good quality spacers aren't an issue?
Offline bmm
« Reply #4 on: 01 September 2011, 15:28 »
I've done over 1000 miles on them so far and not a hint of trouble, and my brother wasn't worried about me using them, though I'll likely replace them with something better at some point soon out of principle ;)
Offline cняis
« Reply #5 on: 01 September 2011, 19:18 »
My 15" BBS RZ's clear the 280mm calipers fine  :smiley:
Offline Mr Blue
« Reply #6 on: 01 September 2011, 20:55 »
RZ's were found on g60 corrados so will fit.
For the RA's I would personaly have the backs milled and then send them off for refurbishment.
Spacers are safe but anything over 5mm then you will need longer wheel bolts
Offline sprout99
« Reply #7 on: 02 September 2011, 10:11 »
Thanks in advance
won't fit
i had to use std 16v callipers and g60 carriers
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Mark 2 Mark
« Reply #8 on: 02 September 2011, 12:20 »
Thanks in advance
won't fit
But would it work with spacers from your experience?
Offline sprout99
« Reply #9 on: 02 September 2011, 12:23 »
Thanks in advance
won't fit
I honestly don't know - it was maega tight with set up i had.
Oak green mk2
V50 D5 Sportwagon
