Author Topic: Fibre glassing and repairs.  (Read 3759 times)
Offline wakejackv5
« on: 30 August 2011, 12:35 »
Hey Guys.
Been looking into smoothing the boot badge (not handle) on MK4s (when i finally pick mine up on the weekend! delayed payment thanks to the bank holiday)
Ive seen people use that expanding foam that is used on building sites to fill holes in walls and then shaping that, then fibre glassing over the top and finishing with a couple of layers of filler. Is this the best way for it?
Any links or advice would be a great help.
Also on the rear bumper there is a slight chunk taken out from where something has been dragged out of the boot, would it be best to just smooth over with body filler and sanding back? (its is very slight but im picky)
All help is greatly appreciated.
Offline Len
Re: Fibre glassing and repairs.
« Reply #1 on: 30 August 2011, 12:39 »
I wouldnt recommend using fibreglass on metal as it has little or no key and will crack or craze around the joint.
www.sas.org.uk
www.the-ace.org.uk
bullens
« Reply #2 on: 30 August 2011, 12:42 »
boot needs welding up with abit of sheet metal as flush to the rest of the boot as possible then a thin skim of filler
Offline wakejackv5
« Reply #3 on: 30 August 2011, 16:58 »
Sweet cheers guys. that make sense for the boot. but bumper wise just rub down filler and smooth?
bullens
« Reply #4 on: 30 August 2011, 17:34 »
depends how bad it is
Offline wakejackv5
« Reply #5 on: 30 August 2011, 18:12 »
ill post a pic asap.
on the boot do i weld the panel from the inside to fully cover the hole or cut out a size to fit and weld around?
bullens
« Reply #6 on: 30 August 2011, 18:20 »
there is no hole unless you cut out the badge recess
Offline wakejackv5
« Reply #7 on: 31 August 2011, 11:34 »
Oh yeah of course. so just plenty of filler?
Offline Len
« Reply #8 on: 31 August 2011, 12:52 »
Yes
www.sas.org.uk
www.the-ace.org.uk
bullens
« Reply #9 on: 31 August 2011, 13:54 »
no, weld metal plate into the recess as flush as possible to the rest of the boot, grind down welds, thin skim of filler
