Author Topic: Audio Wiring Kit Required (Installing Sound - MK3)  (Read 2066 times)
Offline mosdef
Hi,
I was hoping someone can tell me what wiring kit i should purchase.
I am going to install a Alpine MP3 player - 6*9's, sub and amp. in my 5 door mk3.
The wiring should be good - not the best but good - medium range.
Just need some recommendations so i can find em on ebay.
Thanks
Also i read on this forum some mixed views about 6*9's on the parcel shelf - where else could i put them!? would they fit into the rear door compartments and would that work?
Ta
Offline animaniac
Re: Audio Wiring Kit Required (Installing Sound - MK3)
« Reply #1 on: 12 May 2005, 03:59 »
wires wire!!
the thicker it is the better it works! well thats the power cables
speakers are normaly connected by by oxygen free cable... but you would probibly struggle to notice the difference!!
as i've read in many hifi mags in my early teens!!
good thick cable will give you best results!!
the only thing is quality basicly how long will it last before falling apart... i've always use cheap stuff!
and never had any problems.... theres on  3wires to the amp
power, earth, and remote from head unit!
and then you have 2 for 4 wires running to the subs depending on how many you have!
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 15 May 2005, 18:00 »
I'd put the best wire in on day 1. then if you want to upgrade further down the line the power wire is already in there.
Mk4 Golf 150PD
Offline lostplanetj
  • mmm
« Reply #3 on: 15 May 2005, 22:59 »
i bought one of these kits recently seems ok but you may want to add another RCA cable depending how ya gonna do it and the earth wire for the amp is a bit short for where i put mine in MK2
http://www.caraudiodirect.co.uk/product_info.php?products_id=206&cadid=08c3198d7e92c0aee95678c85255352c
lots more depending on budget
http://www.caraudiodirect.co.uk/index.php?cPath=73_56_58&cadid=08c3198d7e92c0aee95678c85255352c
cheapy speaker wire that i didnt need in the end
http://www.caraudiodirect.co.uk/product_info.php?products_id=3410&cadid=08c3198d7e92c0aee95678c85255352c
HTH
« Last Edit: 15 May 2005, 23:07 by lostplanetj »
