Author Topic: Limp Mode  (Read 1406 times)
Offline nikkiy9
Limp Mode
« on: 26 August 2011, 16:39 »
searched the forum but nothing like my issue coming up
turn the engine off for 5 mins and it runs fine, yet after 5 mins of driving the car then limits to 4800 RPM and it is a right biatch to build speed up in it, it jumped into limp mode as i was about to go on the motorway and took 4 mins to get up to 70
i've got a rattle that started this morning from the exhaust (possibly cat)
Offline sharki786
  • GOT BOOST??
Re: Limp Mode
« Reply #1 on: 26 August 2011, 17:11 »
get vag com on to it
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline gasketface
Re: Limp Mode
« Reply #2 on: 26 August 2011, 17:17 »
If only they did viagra for cars  :laugh: :laugh: :laugh:
Offline nikkiy9
Re: Limp Mode
« Reply #3 on: 26 August 2011, 18:06 »
just got home and hooked vagcom up, this is the code it came up with
00561 -  Mixture Adaptation         13-10 -  Adaptation Limit (Mul) Not Reached - Intermittent
« Last Edit: 26 August 2011, 18:09 by nikkiy9 »
Offline javalin
Re: Limp Mode
« Reply #4 on: 26 August 2011, 20:03 »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline gjacko1
Re: Limp Mode
« Reply #5 on: 27 August 2011, 10:02 »
we had the same problem and spent loads on it but in the end it turned out to be the lamda sensor. try that first.
Offline nikkiy9
Re: Limp Mode
« Reply #6 on: 27 August 2011, 12:03 »
as I said, the exhaust has a bad rattle from cat, so hopefully that'll sort it
