Author Topic: braided pipe  (Read 2058 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
braided pipe
« on: 23 August 2011, 08:56 »
The braided pipe that is to the right hand side of the inlet manifold and goes under the metal plate in front of the inlet manifold is deteriorating. What is it, and can I replace it with a sillicone pipe instead. Would it be about 3m.
Thanks
Darren
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline StusDUB
Re: braided pipe
« Reply #1 on: 23 August 2011, 09:08 »
Thanks
Darren
have u got a pic mate?
Re: braided pipe
« Reply #2 on: 23 August 2011, 10:06 »
Here is the front where it goes under the inlet manifold
Here is the back where the pipe is badly deteriorating with a screwdriver pointing to it
Offline tg1
Re: braided pipe
« Reply #3 on: 23 August 2011, 10:07 »
is it an agu? think its the pipe that goes to the top of the dv?
if it is will be fine to replace
Offline StusDUB
Re: braided pipe
« Reply #4 on: 23 August 2011, 10:09 »
+1
Re: braided pipe
« Reply #5 on: 23 August 2011, 10:24 »
It is a 2001 AUM. The pipe is quite short and goes into a thin metal tube at the back, while at the front  it goes under the metal plate in front of the inlet manifold.
This may be a better picture of it, and to the left is another braided pipe that is short and goes under the inlet manifold as well
Thanks
Darren
Offline Sammie-GTI
Re: braided pipe
« Reply #6 on: 23 August 2011, 10:31 »
its the pipe that goes into the top of your DV. most people replace it with 2-3mm silicone pipe anyway
Offline GunnerCP
Re: braided pipe
« Reply #7 on: 23 August 2011, 10:34 »
Replace both of them while you're there, the one you're talking about goes to the fpr though.....
Can't remember if I used 3 or 4mm though.
Re: braided pipe
« Reply #8 on: 23 August 2011, 10:51 »
Thanks. I tried to follow the thin metal pipe the braided one joins into back to the dv, but it is difficult to do that, but I see what you mean now though.
Sorry but what is the fpr.
Thanks
Darren
Re: braided pipe
« Reply #9 on: 23 August 2011, 10:58 »
Ahh found it now; Fuel Pressure Regulator  :smiley:
