Author Topic: CV Joint  (Read 3129 times)
Offline benvictors
  • bgk Tuning - coming soon!!!
CV Joint
« on: 22 August 2011, 20:57 »
Is this terrible annoying noise a fooooked CV joint
http://www.youtube.com/watch?v=7jX9ucclv3k
If so is there a fix or is it straight replacement.
Cheers in advance
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: CV Joint
« Reply #1 on: 22 August 2011, 20:59 »
haha quality video mate
Need new one if its deffo the CV joint mate, did you feel any play ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline benvictors
Re: CV Joint
« Reply #2 on: 22 August 2011, 21:01 »
No play and dunt make a sound in reverse  :undecided:
Offline F17BAD
Re: CV Joint
« Reply #3 on: 22 August 2011, 21:03 »
it makes a sound when out of gear tho yea?
i still think CV joint, im gonna get russ to look at the video
Offline benvictors
Re: CV Joint
« Reply #4 on: 22 August 2011, 21:06 »
Ye even coasting it makes that noise
Offline tshirt2k
  • Been there...Done that...
Re: CV Joint
« Reply #5 on: 22 August 2011, 21:11 »
Don't sound like a cv joint to me! Sounds like a rubbing. A cv is more metallic on an outer, inners usually are felt as a rumble.  How longs it been happening? What suspension do you have?
Mk3 ABF 16VT Megasquirt V3
Offline barrym381
Re: CV Joint
« Reply #6 on: 22 August 2011, 21:12 »
have you checked the wheel bearings mine broke up on my mk4 turbo an wasnt to far away from that noise
Offline tshirt2k
Re: CV Joint
« Reply #7 on: 22 August 2011, 21:16 »
Obvious question. But are your wheel bolts tight? I see wheels have been added recently.
Offline benvictors
Re: CV Joint
« Reply #8 on: 22 August 2011, 21:35 »
Ye checked for rubbing, wheel bolt tightness etc etc, started about 4 days ago and has gradually got worse, my initial thought was wheel bearing but there is no play in the wheel and doesnt sound like the normal wheel bearing sound, the sound almost goes away on hard right.
Offline tshirt2k
Re: CV Joint
« Reply #9 on: 22 August 2011, 21:55 »
What did you do 4 days ago? Sounds like something simple dont sound cv or bearing related. It's like a creak but sounds rubbery as the speed gets up. You tried changing wheels to eliminate those. Possible high offset problem?? Hard to tell from the vid.
