Author Topic: 16v engine conversion questions...  (Read 2266 times)
Offline arkeye
« on: 22 August 2011, 18:30 »
hi everyone, thinking about doing this mod. i have read this sticky http://www.golfgtiforum.co.uk/index.php?topic=124485.0
so just to clarify then. i can buy a 16v engine and bolt it straight in with the 8v gearbox?
what downside is there running the 8v gearbox? top end im not bothered about as i dont really intend going much over a ton at the best of times, as long as im not doing 6000rpm at 70mph!!!  :grin: :wink:
if there are big downsides then i will swap to the 16v gearbox and obviously change the clutch mechanism to a hydraulic one.
what are the parts i need? new engine mounts, engine, what else?
from the sticky it mentions about a new ecu can someone explain more about this? and anything i may have missed out would be great
Re: 16v engine conversion questions...
« Reply #1 on: 22 August 2011, 19:13 »
What car have you got at the moment. :smiley:
Offline madmanmart
« Reply #2 on: 22 August 2011, 19:32 »
I take it your running a GTI 8v? I have done this conversion myself.
I seriously would not run the 8v box, they are very fragile and will no doubt break.
You need:
Engine + box
Hydro clutch setup
Cable shift setup
16v engine bay loom
ECU
Transponder + chip in key
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 22 August 2011, 20:54 »
8v box will be fine for dialy use, i swapped my old 8v box into the 16v car i had which i robbed the box for my S3 converison
the 16v car is going strong and the new owner rags it to death. its faster off the line than before.. but who knows how long it will last the way he drives
Id rather have the propper set up and run the hydro set up and ABF gearbox etc
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline arkeye
« Reply #4 on: 22 August 2011, 21:35 »
yes i have an 8v gti.
could the 16v gearbox and hydraulic clutch system be fitted later down the line, after the engine is in and ive had some fun?  :evil:
Offline F17BAD
« Reply #5 on: 22 August 2011, 21:53 »
yeah
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #6 on: 22 August 2011, 23:11 »
If you are running the 8v box then you will just need the engine, engine loom, ecu and transponder box and chip if the ecu is immobilised.
I would replace the rear engine mounts and you will need to put the 8v flywheel, pressure plate and clutch on the 16v engine before fitting the 8v box.
« Reply #7 on: 22 August 2011, 23:52 »
Why do you want to fit a 16v. :huh:
Offline arkeye
« Reply #8 on: 23 August 2011, 07:09 »
more power and it will be a little project as i like tinkering
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #9 on: 23 August 2011, 08:03 »
Not that much more power though, it's a lot of effort with doing the gearbox as well for quite a small gain imo. Will the 16v be staying standard?
