Golf mk3
hardmonkeys
drivers door lock freezes in winter...
Topic: drivers door lock freezes in winter... (Read 1672 times)
javalin
22 August 2011, 10:58 »
Hello,
I've got my drivers door appart to cure the lock freezing in the winter, but can't see anything obviously wrong that would allow water in and freeze.
Suggested by a mate to cover with greese?
Any other tricks?
Pics here -
http://javalins.wordpress.com/2011/08/21/golf-mk3-drivers-door-strip/
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
DigitalDogg
Re: drivers door lock freezes in winter...
22 August 2011, 12:56 »
the same happens to me every year, im glad you have brought this issue up because i need help too
i've been running warm water over the lock and it dose your head in at 5.30 in the morning
javalin
22 August 2011, 13:06 »
or having to climb in through (at best) passenger side, (medium) rear doors or (worst) via a window....
J
nikkiy9
GTI forum regular
22 August 2011, 13:50 »
fit a remote central locking kit, it removes the need to use the key to open the car
mellow yellow
A Driffield Dubber!
22 August 2011, 14:27 »
i just leave mine open
... or fill a bottle of warm water and pour it over the lock to defrost it. i think its just one of those things you have to put up with if you dont have remote locking.
javalin
22 August 2011, 14:41 »
I do have remote locking, but what happens is that handle will move and the pump runs, etc, but the pins which "lock/unlock" the door get frozen stuck. So whilst you can move the mechanisum, it doesn't open the door as its still locked....
Jack3559
Reply #6 on:
22 August 2011, 14:59 »
Drape a towel over the drivers door.
trog_nfs
Reply #7 on:
22 August 2011, 15:02 »
Clean up the lock and mechanism the best you can, then pack with some good grease like LM grease that won't just wash away. Should do the trick
javalin
Reply #8 on:
22 August 2011, 15:11 »
good idea - how about marine grease - i.e. its designed not to wash away with water.
http://www.ebay.co.uk/itm/Unipart-Waterproof-Marine-Boat-Grease-bearing-sterntube-/250873715084?pt=UK_CarsParts_Vehicles_BoatEquipment_Accessories_SM&hash=item3a693d198c
trog_nfs
Reply #9 on:
22 August 2011, 15:22 »
can see no reason why not. Wheel bearing grease (like LM) works well too, used to use it to lube my coilover threads up, didn't wash away in a hurry
Golf mk3
hardmonkeys
