Author Topic: drivers door lock freezes in winter...  (Read 1675 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: drivers door lock freezes in winter...
« Reply #10 on: 22 August 2011, 18:03 »
Is it winter again already?  :undecided: :sad: :cry:
Offline javalin
« Reply #11 on: 23 August 2011, 08:37 »
not quite :-)
Just fixing the problem (I hope) before then!!!
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
  • The bear that khares
« Reply #12 on: 23 August 2011, 10:42 »
Clean up the lock and mechanism the best you can, then pack with some good grease like LM grease that won't just wash away. Should do the trick
That's the best thing to do. The other option is one these http://www.ebay.co.uk/itm/defrost-key-ideal-solution-frozen-locks-/320747571004?pt=UK_Collectable_ToolsHasdware_RL&hash=item4aae0b873c#ht_500wt_1156, although I've never tried one or heard reviews about them.
Pouring warm water over it makes it worse, as it'll just make it freeze up the next morning and will cause the lock to rust out eventually.
Offline javalin
« Reply #13 on: 23 August 2011, 10:47 »
Hiya
Thanks, I covered with grease last night.  I think I got into it enough - its tucked away a bit.  Have also ordered the spray variety, might do some more maybe....?
I think I can see what might have been going on.  The outer (towards the outside of the door) window rail terminates above, or near the lock so I wonder if it was funnelling the water into the lock when it rains.
Got it done last night, before todays rain - didn't want to grease the wet in!
Last picture... http://javalins.wordpress.com/2011/08/21/golf-mk3-drivers-door-strip/
James
