Author Topic: Slight misfire :( HELLLPPPPP !!!!  (Read 1480 times)
Offline curtis1993
« on: 21 August 2011, 22:36 »
Hello people ... my 1993 1.8 8v has a slight misfire on idle exhaust is blowing ever so slightly could that cause it ... you can feel the miss fire at low revs and some times high if you open the bonet you can hear a sucking in noise if that makes sence broken pipe ??? i am no mechanic so any ideas are welcome the car seams to be drinking fuel like i do water as well cost me just about 10 quid to do 30 miles :( the fuel price where i am is 130.9 as well :(
Helppp meee !!!! i wourk 30 miles away from work so this is costing me alot of money !!!
Cheers guys :D
Built Not Brought!
Kaitlin The Mk3 Golf
http://www.golfgtiforum.co.uk/index.php?topic=201772.0
Offline WadGTI
  • Golf GTI'er
Re: Slight misfire :( HELLLPPPPP !!!!
« Reply #1 on: 21 August 2011, 22:49 »
I have the same sooking noise - but I think it could be normal on the golf gti???
I have checked all the breathers and vacuum hoses and they are all on good condition. My old polo used to make the same noise and a stud was sheared of the block which held the exhuast manifold and was blowing from there. It never got the greatest mpg as I think it was loosing compression. I could be wrong on this - but thats my 2 cents.
Have you checked the exhuast system?...Mines is not in the best of condition - has a 10 year old rotted back box on it.
As for the misfire - timing may be slightly out I think.
Offline curtis1993
« Reply #2 on: 21 August 2011, 22:57 »
mine not a gti unfortunatly just a cl :(
i duuno my exhause is blowing think its time for a new one .. the cam belt is being done next saturday so i am sure we can find out if the timing is out then ... if thats how we find out .. then i think its time for a new exhaust :/
Built Not Brought!
Offline patc
« Reply #3 on: 21 August 2011, 23:01 »
130.9?!  I can only dream of it that cheap round here  :sad:
Good luck with the car though.
PatC
Golf GTI MK3 Anniversary Edition
Offline Seanl
« Reply #4 on: 22 August 2011, 08:55 »
When was it last serviced? If its been a while, I'd go for this as a first port of call. Change spark plugs and leads too. Obviously check all vac hoses and breather pipes, and make sure they are all firm and intact. Get someone to rev whilst you look over, and try and pinpoint the noise. If you can see the breather pipe compressing whilst at revs, replace it. Dizzy could also be at fault for the misfire, and a few others.......
Offline Len
« Reply #5 on: 22 August 2011, 09:22 »
Dizzy cap and rotor arm, plugs and leads, ECU relay.
Plus vacuum hoses.
www.sas.org.uk
www.the-ace.org.uk
Offline danmusic24
« Reply #6 on: 22 August 2011, 09:46 »
Cheers guys :D
had the same issue a while ago mate! check the stiff thin pipe that runs from inlet manifold(right hand side) back to servo,mine had cracked where it meet the servo took me ages to find that out and caused the problems you are having.its bastard to get too but could be worth a look... :smiley:
Offline trog_nfs
« Reply #7 on: 22 August 2011, 10:12 »
1.8? Check the rubber gasket between the throttle body and inlet manifold, they are prone to splitting.
