Author Topic: using alot of oil and water  (Read 2347 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 21 August 2011, 19:32 »
right i think i am use alot of oil and water check the dip stick before and was empty  :shocked: no warning light plus sames to of used abit of water aswell.
i am going to monitor it this week.
got no smoke out the back its not over heating so abit baffled.
Offline Toby
  • Car - less
Re: using alot of oil and water
« Reply #1 on: 21 August 2011, 22:29 »
Mayo in the oil cap? No sins of leaks when you move the car?
Currently down under
Offline bbewekim
« Reply #2 on: 21 August 2011, 22:31 »
when you say not overheating, you tested on vagcom or just the needle? The needle will sit on 90 until the temp is like 105-110 i think.
Checked for obvious leaks? Any muck/or white stuff on the oil cap?
« Reply #3 on: 21 August 2011, 23:26 »
I would get the coolant system pressure tested then the head gasket with a block tester.
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 21 August 2011, 23:37 »
A 1.8T can use oil if you nail it. But if you're losing coolant and there's no external leaks, then hide your wallet.
'09 Kawasaki Ninja ZX-6R
Offline (shakey)
« Reply #5 on: 22 August 2011, 13:57 »
just by the needle m8 but the engine was real hot last night when i lifted the hood hotter than normal.
Offline (shakey)
« Reply #6 on: 22 August 2011, 13:58 »
just hope its not the
how do you do a coolant pressure test wayne?
gpt no mayo on the filler cap so think head gasket is ok just hope its not the piston rings .
Offline Ant1981
  • Feed me, prod me
« Reply #7 on: 23 August 2011, 13:09 »
No mayo doesn't mean the gasket is ok though.
Offline (shakey)
« Reply #8 on: 23 August 2011, 15:33 »
o right didnt know that.
think i found what the prop is but need to get under car got than oil leak but only when the car has been running it start to leak slowly its coming from between the engine and gearbox,its stops leaking when the car has not been running for abit.
so will it be seal or cracked block i know i need to look but just want ideas before i start looking.
Offline Ant1981
  • Feed me, prod me
« Reply #9 on: 23 August 2011, 17:07 »
Rear crankshaft oil seal.
Oil is thinner when hot, that'll be why it looks ok when cold.
