Author Topic: Help i grounded out  (Read 2080 times)
Offline sellers
  • Daz Works in Health and Beauty
Help i grounded out
« on: 16 April 2005, 21:31 »
just grounded my car as i was doing a 3point turn in the road i purposly went a bit on some grass to save doing as many turns, but the grass was slightly downhill so it grounded out quite hard,i  managed to drive it off the dip but now i get vibrations all through the car and as the revs get higher they worsen, is there any ideas of what iv done? i cant see any holes in the exhaust?
please help me
Can't think of a funy or whitty comment
Offline Mr Blue
Re: Help i grounded out
« Reply #1 on: 16 April 2005, 21:37 »
smacked the tracking out ?  :undecided:
Offline piggy
  • What you lookin' at sonny?
« Reply #2 on: 16 April 2005, 21:55 »
You moved the exhaust so that it's rubbing against the bodywork/heatsheild?
Worth checking the gap and pulling it away a bit.
When it rubs it sounds like the whole car is vibrating / buzzing :tongue:
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 16 April 2005, 22:27 »
I've been living with a rubbing exhaust for years now lol.
Offline sellers
« Reply #4 on: 16 April 2005, 23:07 »
i hope its as easy at that, feels like im driving a tractor which is all i need doing a 600mile round trip at next wk end, i'll have a look 2moz and get back 2 u lot
cheers guys :smiley:
Offline sellers
« Reply #5 on: 17 April 2005, 12:43 »
tried havin a look and luck, could the exhaust have push up into the engine pushing it forward as i was reversing at the time?
any help guys, lol
Offline monzablue16v
« Reply #6 on: 17 April 2005, 21:18 »
u need a big 4 post ramp take it to your garage for the tracking doing and have a good look underneath whilst its up tracking is most obvious or bent tie rods etc best to check the longer it goes the more expensive it gets  :sad: also check engine mounts and sump etc get under  and have a look with a trolley jack and axle stands you can do it!!!
Offline sellers
« Reply #7 on: 17 April 2005, 22:10 »
when it grounded it was about in the middle of the car so i dont think it would have damaged angine mounts or tracking would it? as i was only doing about 5mph,
on closer inspection before, this is from trying to get my head under to have a look, i noticed the lug on the exhaust behind the mid box is an inch further up towards the manifold than the lug on the car body and the rubber holder between them has snapped?
Offline sellers
« Reply #8 on: 18 April 2005, 00:05 »
right iv decided after work im gonna go to quick fit so atleast they can get it on a ramp and get me a quote for what needs doing ahem* i mean tell me whats wrong ha ha :laugh:
Offline sellers
« Reply #9 on: 18 April 2005, 17:59 »
well, i took it to quick fit and they have found that it has peen pushed forward and has bent slighty and therefor part of it is hitting the steering rack, dropping it off 2moz to see if they can heat it up and bend it back :smiley:
otherwise its a new front down pipe
