Author Topic: White dial kits  (Read 3593 times)
Offline CM690
  • Golf MK4
White dial kits
« on: 15 August 2011, 19:41 »
I've always wanted the white dials you find in some higher spec mk3's but don't' want a mileage change so I thought about getting one of these kits.
http://www.ebay.co.uk/itm/VOLKSWAGEN-VW-GOLF-Mk3-1991-1999-WHITE-DIAL-KIT-/120709181224?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1ad3ef28
Dirt cheap right? :P
Well my question is my car 1.4 CL and the dials are 0-140mph which is fine but the revs side is completely different to any I can find! It goes from 0-6000rpm and the dials are either 7 or 5? Could I get a 7,000rpm kit or will that "not read correctly" obviously I know when to change gear but I want the rest of the dials to read correctly :)
What do you think?  :undecided:
Offline dansmk3
  • FULL TIME JUNGLIST
Re: White dial kits
« Reply #1 on: 15 August 2011, 19:50 »
personally id say stay with the spec that is original to the car, yes the revs would be inaccurate.
iv had a look and i think the only way to get your dials white is to change the clocks. iv just had a search myself. unless someone on here has already done it and they post up some links
one thing i want to know is whats the best way to make your needles the glowing orange colour.
Offline dansmk3
Offline Seanl
Re: White dial kits
« Reply #3 on: 15 August 2011, 20:16 »
Have a look in the maint section. A few have changed leds and backlit the needles to glow different colours but I cant be arsed to find the link!  :grin: Another way to light the needles is to use florescent paint on em.
Offline dansmk3
Re: White dial kits
« Reply #4 on: 15 August 2011, 21:00 »
aint a halfrauds jobbie is it?
Offline Seanl
Re: White dial kits
« Reply #5 on: 15 August 2011, 21:44 »
I suppose you could if you dont mind orange, pink or yellow.  :sick:
Offline dom
  • Back in a Mk4
Re: White dial kits
« Reply #6 on: 15 August 2011, 22:02 »
I did a guide a while ago:
http://www.golfgtiforum.co.uk/index.php?topic=181457.0
Sold the car with these in, really should have swapped them and let someone else have them :cry:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: White dial kits
« Reply #7 on: 15 August 2011, 22:53 »
Ive purchased uv fishing float paint in the past, the colour is spot on. Failing that there's,also a seller on eBay based in the USA that sells proper UV needle paint for a few quid which I've also had and tbh there wasn't much difference in colour or night visibility.
Re: White dial kits
« Reply #8 on: 15 August 2011, 23:04 »
These are the proper clocks that you are looking for : http://www.ebay.co.uk/itm/VW-GOLF-MK3-SPEEDO-SPEEDOMETER-1H0-919-913-C-/270732816240?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f08eeef70
Ive been a bit of a speedo geek since I've owned this last mk3 and seem to keep aquiring different ones to pull apart or modify.
I've now got a couple of standard ones, 1 8v Annie set, 1 16v Annie set and another set of 16v with silver lockwood faces and tweaked lighting. LOL  :nerd:
Offline CM690
  • Golf MK4
Re: White dial kits
« Reply #9 on: 15 August 2011, 23:47 »
Thanks, damn they're cheap :O but I'd rather keep my original mileage hence the dial kit :( though these are very tempting indeed
