Author Topic: Help with washers please!  (Read 3589 times)
Offline kuvalee
  • Approved vag painter since 1999
« on: 15 August 2011, 18:50 »
Right my washers have stop'd working all fuses ok checked there is a circuit connected washer motor straight to the battery and it worked changed the old connections on the motor but still nothing oh and also tried a new motor any help would be great.
« Last Edit: 20 August 2011, 13:45 by kuvalee »
Offline kuvalee
Re: Help with washers please!
« Reply #1 on: 15 August 2011, 19:26 »
just checked the circuit again and the test lamp only lights up dim when connected on the negative circuit and really bright on the positive.
Offline SoundillusioN
« Reply #2 on: 16 August 2011, 10:05 »
What are you connecting the bulb to.  Not sure I know what you mean when you say you get a dim light from negative....
Offline kuvalee
« Reply #3 on: 16 August 2011, 18:03 »
soundilllusion i have just put a multimeater on the connections on the pump then pulled the stalk a voltage of 1.6 was passed through then spiked the positive wire at the back of the fuse box and the same current reading so do's this mean that the relay has gone as there should be a reading of 12.00 to 12.06 volts? also the mfa has now stoped working as well!!
« Reply #4 on: 18 August 2011, 10:45 »
I'll check through the setup of mine and get back to you.  Are all the earths next to the fusebox OK?
Offline kuvalee
Re: Help with washers please! and now mfa!
« Reply #5 on: 20 August 2011, 13:10 »
yes all earths are fine and all connected to the crowns.
Offline kuvalee
« Reply #6 on: 21 August 2011, 19:39 »
is this what i need head light washer realay 431955535 number 33?
« Reply #7 on: 22 August 2011, 09:28 »
Yes Relay 33.  :wink:
For future reference on all things electrical.
Click  :cool:
