Author Topic: Rear Wiper Problem...  (Read 5280 times)
Offline X4MGS
  • VAG Parts SNOB!!!
« on: 15 August 2011, 18:16 »
Anyone else got this problem or can someone offer a possible solution.... Plz... :smiley:
Rear wiper only swipes once and stops - Most of the time but not always - Really bloody annoying.. :angry:
Had a play with it yesterday and tried a new(ish) No72 relay.. still does the same...
Could it be a fault with the motor unit? But I thought it was controlled by the relay  :undecided:
For More Info Click To See;
Offline The Mighty Elvi
  • I'm better than you today.
Re: Rear Wiper Problem...
« Reply #1 on: 15 August 2011, 18:22 »
Faulty stalk.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 15 August 2011, 18:24 »
Faulty stalk.
Hope not it's only 4 months old from BBT - Cost me over £50.00...
Offline Pluginz
« Reply #3 on: 15 August 2011, 18:53 »
Hello bud.
  Open the boot and look at the top left where there is a rubber boot.  Pull that out and see if the wires are broke there.
They seem to chaff on the bodywork i think, when you open and close the boot over time.  If you do have to repair them it can be a pain in the butt.
  Best to remove the headlining and you can get to them easy then.
 :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 15 August 2011, 19:04 »
Did have a fiddle with the wires as I had that problem before but when that happened the whole unit didn't work at all...
Might have another look tomorrow just to make sure...
Offline mwep201081
« Reply #5 on: 15 August 2011, 19:14 »
out of interest, what are you expecting it to do?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 15 August 2011, 19:21 »
What is should do... a combined wipe - flat and back to the parked position in 1 sweep....
« Reply #7 on: 15 August 2011, 19:57 »
 :grin:
Offline katana
« Reply #8 on: 15 August 2011, 21:32 »
Mine was very slow - stripped it out & freed off the spindle, now it works fine
Just a thought  :wink:
Offline walchy01
« Reply #9 on: 15 August 2011, 21:39 »
Replace the wiper motor, it's on it's way out... Mine currently doing exactly the same thing and yes, it is bloody annoying stopping half way thru the swipe :angry:
