Author Topic: Rear Wiper Problem...  (Read 5282 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Rear Wiper Problem...
« Reply #10 on: 15 August 2011, 21:52 »
Replace the wiper motor, it's on it's way out... Mine currently doing exactly the same thing and yes, it is bloody annoying stopping half way thru the swipe :angry:
I've got plenty of spares so will pop a new one on tomorrow...
For More Info Click To See;
Offline weazgti
« Reply #11 on: 15 August 2011, 21:53 »
It will be a broken wire, common fault that i had to do myself recently.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #12 on: 15 August 2011, 21:56 »
I'll check those too, but I doubt its a wire as it actually works...
Offline weazgti
« Reply #13 on: 15 August 2011, 22:14 »
Had the same. It parked different place every time.
Thought the wires were ok utill i pulled one and found some black tape on an end of a wire.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #14 on: 15 August 2011, 22:16 »
Mine parks in the same place every time... Just either at the | or _ position...
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #15 on: 15 August 2011, 23:31 »
Broken wire syndrome, wiper could well still park! also check that No plate lamps are still working. Pull the rubber sheathing back, and have a proper look, and also give the wires a tug, just incase the wire may have broken inside its own plastic coating...
If you find broken wires, don't just solder them back together, add a new 8 inch piece in, so you can tuck the wire back into the roof, and leave brand new wire, where it is most vulnerable to break again... should last another 20 years :wink:
Thom
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #16 on: 15 August 2011, 23:54 »
Thom
Wires it is then.... 1st inst...
Sure I have a complete tailgate loom lying around (somewhere)... I know mine has had a new tailgate in the past and the wires had been cut (fecking lazy body shop)... Only takes 10 minutes to pull the whole loom out in 1 pc... :nerd:
Offline Craigwilson
« Reply #17 on: 17 August 2011, 00:32 »
My rear wiper works fine but then stays on doing single wipes every 30 seconds whys this?
Have to kill the ignition and start it agen on the move to stop it.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #18 on: 17 August 2011, 00:36 »
Try a new relay #72
Offline Craigwilson
« Reply #19 on: 17 August 2011, 00:57 »
Will do
