Author Topic: Huge hole in air box?  (Read 4176 times)
Offline DigitalDogg
« on: 14 August 2011, 18:21 »
hi guys,
i've had holes drilled in my air box for a few years now with a K&N panel filter fitted, but was at a mates house today talking about drilled air boxes and he said he had a air box from a 8v with a hole cut out of it that i could have...
when he showed me it i thought... o sh!t... will that be ok on my car?
sorry about the blur'd photo
is this hole to big?and will it just suck to much air in?
cheers
VW BUSH
Re: Huge hole in air box?
« Reply #1 on: 14 August 2011, 19:31 »
If you have an 8v, yes.
Hole might pull in hot air from strut tower area though :undecided:
Going to do me a new airbox soon, was going to try something a little different this time :lipsrsealed:
Offline DigitalDogg
« Reply #2 on: 14 August 2011, 20:30 »
just fitted it and took up the road for a couple of miles  :grin: i was grining all the way  :grin: the sound was lovely, there is a big deferents from having just holes drilled, the car roars now but cant floor it in first gear, it just revs out :cool:
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #3 on: 14 August 2011, 22:01 »
There is a big write up on this exact modification on Google.  I would say it is fine if you put a good direct feed to it.  On my VR6 I removed my fog light and took my direct air feed from there.......Will put pics up tomorrow.  Induction noise will be better and many have found that modding the airbox gives more power than an induction kit as the induction kit is exposed to heat soak.
Offline DigitalDogg
« Reply #4 on: 15 August 2011, 12:22 »
i've just won a airbox on ebay and going to try and connect cold air feed from bumper vent, which pipe will be best for this? will it have to be heat proof?
cheers
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 15 August 2011, 16:12 »
cheers
Remove the drivers side fog light......Easy job.  From there you can house your direct feed. I dont have my camera on me but will have tomorrow so will take a few pics of how I have done it with a step by step guide for you  :smiley:
Offline DigitalDogg
« Reply #6 on: 15 August 2011, 18:18 »
cheers
cheers  :smiley: i have three airboxes now, one with holes drilled, one with a big hole cut out and the third im just going to try a direct feed with no holes drilled, then see which one will be best...
Offline Seanl
« Reply #7 on: 15 August 2011, 20:19 »
Wouldnt bother with removing the fog. Run the cold air feed to the lower bumper grille. Perfectly good there without sacrificing a fog light.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 15 August 2011, 23:11 »
Having tried various routes and options for the cold air feed I'd say either opt for the lower bumper  vent but run the risk of hydrolocking in the winter or as I'm now running,  utilising the original wing opening minus all the plastic gubbins and restrictive airbox intake  pipe with a 3" duct pipe in its place.
Offline DigitalDogg
« Reply #9 on: 16 August 2011, 13:55 »
thanks for letting me know about hydrolocking, i never knew about this and just googled it...
scary stuff
cheers
