Author Topic: what a stupid way to build a car  (Read 1510 times)
Offline bricey
  • One of a few with a PROPER engine
« on: 13 August 2011, 18:10 »
evening chaps,
right i set about doing my wishbone bushes and putting poly ones in there,
all way going well done the passenger side but had to replace the outer tie rod arm (dont ask)lol
so i jacked up the drivers side and undid the 3 bolts holding the wishbone to the hub and then moved to the front bolt and what is in the way of me getting that bolt out.......have a guess....no.. the SUMP. :sick:
now am i right in thinking the only way that bolt is coming out is if i drop the subframe?????
because there is no way on this planet that bolt is coming out????
cheers
james
DOLPHIN TRAINER
Offline Thom89
  • Looking for an "Icebreaker"
Re: what a stupid way to build a car
« Reply #1 on: 13 August 2011, 19:38 »
I cant think for the life of me what the set up looks like on a Mk4, but quite a few cars have a similar situation, resolved by undoing the bolt, moving it out as far as possible, and hacksawing the bolt in half to remove, replace with a new bolt, fitted the other way round...
Thom
Gavv8
« Reply #2 on: 13 August 2011, 20:56 »
Being a 4motion i would imagine it's fairly crowded underneath, have you tried a search to see if there any exploded diagrams online?.
Offline Bellend
« Reply #3 on: 13 August 2011, 23:35 »
Same on my MK3.
Jack on the sump with a block of wood (not the car, support the car then jack up the engine) and I did it.
Can loosen engine mounts too.  :smiley:
Where all my moneys went.
Offline tweed
« Reply #4 on: 14 August 2011, 00:01 »
yep, jack the engine up. use a large bit off wood to spread the weight of your v6
Offline bricey
« Reply #5 on: 14 August 2011, 08:16 »
well i posted up on the r32 forum
and the the correct way to do it is by dropping the subframe. :shocked:
DOLPHIN TRAINER
Offline Ant1981
  • Feed me, prod me
« Reply #6 on: 14 August 2011, 10:53 »
That's not the 'correct' way, that's just the long way.
'09 Kawasaki Ninja ZX-6R
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #7 on: 14 August 2011, 13:06 »
its the factory way not the way of 'choice'  :grin:
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 14 August 2011, 22:05 »
Well there is always a systematic way of doing things in a factory as that's build, but maintenance, there's nothing wrong with undoing engine mounts and moving the engine.
