Author Topic: Fuel filter fitting advice please  (Read 1466 times)
Offline walchy01
« on: 12 August 2011, 15:39 »
Afternoon all
I am in the process of eliminating a juddering issue and have been advised by the guys on here to change my fuel filter, firstly where is it?? And how easy is it to replace??
How long would it take an amateur to do :grin:
Any special tools required??
Thanks
Russ
Offline Steve_B
Re: Fuel filter fitting advice please
« Reply #1 on: 12 August 2011, 15:49 »
Fuel filter is under the car by driver's side rear wheel. Is it 8 or 16v? I think the 16 has solid pipe connections which makes it harder job.
Offline walchy01
« Reply #2 on: 12 August 2011, 16:15 »
Sorry mate, it's a 16v...
Offline mk2bal
« Reply #3 on: 12 August 2011, 17:25 »
Piece of piss to do. Just make sure you use grips or a spanner on the filter ends when undoing the unions, or you'll spin the whole lot and damage your fuel lines. Same applies when refitting, grip the filter as you tighten the banjos. Stick your head under the sill, in front of the o/s rear wheel and you'll see the assembly, the filter is the big canister on its side, but you'll figure that as you'll have the new filter to hand..
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 12 August 2011, 23:14 »
It's a canister resembling a coke can in dimension, or there abouts.  It is held by a wrap over clamp.  The bolt to undo the clamp is a b!tch!.
There is a pipe going into the filter at each end.  These are held on by bolts attached to the end of the fuel lines.  The end of the fuel lines are threaded and the bolts secure the joints.
Take care when undoing the bolts as you do not want to spin or damage/twist/bend the fuel lines.
BE PREPARED for fuel leaking from the filter and pipes. Have a bowl or towel handy.
Remove the filter. Fit the new one and screw in the fuel lines at either end.
They need to be super tight to stop leaks.  But do them up slowly.
« Reply #5 on: 13 August 2011, 10:17 »
Remove the fuel pump fuse and run the car until it cuts out, this will release the pressure in the fuel system
Offline walchy01
« Reply #6 on: 14 August 2011, 09:08 »
Thanks guys some top tips....
