Author Topic: 1.6 with gti cam  (Read 2039 times)
Offline vee-dub90
  • mk3 GTI 16V next year.
1.6 with gti cam
« on: 12 August 2011, 00:19 »
i am going to be putting a gti cam onto my 1.6 jetta, can i just shove it on with the existing cam followers that are being used with the standard cam? or do i use the cam followers that will be coming off the gti head which the cam is coming off?
Re: 1.6 with gti cam
« Reply #1 on: 12 August 2011, 00:23 »
Are they both hydraulic cams.
Offline pigbladder
« Reply #2 on: 12 August 2011, 08:14 »
idealy take the gti cam followers and number them , assuming theyre in good condition and both cars are hyd heads
Offline vee-dub90
« Reply #3 on: 13 August 2011, 00:11 »
the 1.6 is the EZ and the gti is PB
« Reply #4 on: 13 August 2011, 00:15 »
So I guess the EZ is mech followers in which case I don't think it will work.
Offline danny_p
« Reply #5 on: 14 August 2011, 10:23 »
EZ is hydralic
use the followers that cam is used to if there avalible but don't mix them up as there is no advantage in useing them if there mixed up.
you work with the the followers you have in there
all the VW's have gone bar 1.
Offline vee-dub90
« Reply #6 on: 15 August 2011, 23:43 »
so it is a hydro head?
Offline dennis10
« Reply #7 on: 18 August 2011, 13:09 »
The short answer is if they are both hydraulic, then it will fit fine with the cam followers from your existing EZ setup.  I never had a problem when fitting the GTI cam to my old mk2, I cant see you having any either.
