Author Topic: garage wouldn't steam clean my engine  (Read 1463 times)
Offline DigitalDogg
« on: 11 August 2011, 19:32 »
hi guys,
took my car to the local garage today and asked them to steam clean my engine and he said... i wouldn't advise it your car will probably miss after a steam clean, have anybody here had there engines cleaned? and did your car miss at all?
to be honest... i think he couldn't be bothered
cheers
« Last Edit: 11 August 2011, 20:19 by DigitalDogg »
Offline Seanl
Re: garage wouldn't steam clean my engine
« Reply #1 on: 11 August 2011, 20:37 »
Hes talking sh!te. Worth covering up electricals, which I did, then pressure washed mine! Cant see a little steam doing too much damage as long as you steer clear of coil pack, dizzy, and spark plugs. Try somewhere else, and cover those up when you get there. No excuse for them not to do it then.
Offline DigitalDogg
« Reply #2 on: 11 August 2011, 20:52 »
i thought as much :angry: he made me feel like i was walking away with my tail between my legs,
my bother-in-law got a steam cleaner but he never got time to do it, going to ask him every day until he gets fed up with me  :laugh:
« Last Edit: 11 August 2011, 22:22 by DigitalDogg »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 11 August 2011, 21:36 »
I steam cleaned mine,  It misfired all the way home from work,   then it was fine so i took it 70 miles up the road and it died all together, £65 tow fee later...  I fitted a spare coil pack and bobs your uncle.   The morral of the story is,  the coil packs fail well enough without the help of water, so keep it well covered up.   Otherwise, worth keeping the dizzy dry too.   but yea its fine.   WD40 all the electrical connectors,  do it before its wet to keep water out,  otherwise it locks water in  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Gti Gerbil
« Reply #4 on: 11 August 2011, 22:20 »
be careful of the crank sensor wires too
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
Offline DigitalDogg
« Reply #5 on: 12 August 2011, 12:37 »
ok, will cover much as i can, got WD40 ready and going to cover coil pack etc with food bags then tape them up at the bottom, fingers crossed it will be all ok :smiley:
cheers :smiley:
Offline AudiA8Quattro
« Reply #6 on: 12 August 2011, 14:33 »
A garage won't want to do it because if something packs up you will be going straight back to complain.
Can't really blame them...
