Author Topic: Quick wiring query  (Read 1743 times)
Offline jmsheahan
Quick wiring query
« on: 10 August 2011, 13:59 »
I'm wiring up some VDO's and have a quick query (I've had a look through the VDO threads). Is there a spare ignition live terminal on a 90spec fusebox I can just run a new wire from? If not where/what should I run the wire into? Got them working but it's on a constant live at present which obviously is no good. Was going to use the ciggy lighter live but it's a constant live, not ignition.
Please bare with me as I suck at electrics!
Cheers!
« Last Edit: 10 August 2011, 14:01 by jmsheahan »
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Quick wiring query
« Reply #1 on: 10 August 2011, 16:29 »
If you dont wanna take it to the Fuse box then tap into the radio Live as its switched...
Otherwise check out this... Q06 would be my guess...
http://www.a2resource.com/electrical/CE2.html
 :laugh:
For More Info Click To See;
Offline jmsheahan
« Reply #2 on: 10 August 2011, 18:19 »
Cheers Ken. Sorted now, found a spare ignition live hanging from the fusebox. Might be left over from the old alarm or something. Am going to use that.
Whilst on the subject of VDO's, a slight side issue the oil pressure sender I have came from an Audi and is marked 0-5 (gauges were from the same car). Anyone handy with ETKA that could possibly look up the part number 035 919 561? I think it's a sender which goes on the head however the casting is worn and I can't make the rating out.
Cheers  :smiley:
« Last Edit: 11 August 2011, 07:49 by jmsheahan »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 10 August 2011, 21:13 »
that number don't work in ETKA...
Offline jmsheahan
« Reply #4 on: 11 August 2011, 08:10 »
Last digit was a 1 sorry. Managed to clean it up a bit and all of the markings are:
035 919 561
5 90
30/80
0-5 bar
0.3 + 0.15 bar
Does this go in the side of the head or on the cooler?
« Last Edit: 11 August 2011, 08:15 by jmsheahan »
Offline jmsheahan
« Reply #5 on: 11 August 2011, 13:19 »
Now sorted. Does go in the cylinder head. Cheers for the help.
