Author Topic: Best head for a g60 16v conv  (Read 3343 times)
Offline busterdub
« on: 09 August 2011, 19:18 »
Hi all
After some info building a g60 16v engine what's the best head to use?
Re: Best head for a g60 16v conv
« Reply #1 on: 09 August 2011, 20:59 »
What are planning for the bottom end.
Offline busterdub
« Reply #2 on: 09 August 2011, 22:14 »
G60 block from a corrado
« Reply #3 on: 09 August 2011, 23:57 »
I think you will need to run an 8v head then :undecided:
Offline danny_p
« Reply #4 on: 12 August 2011, 00:26 »
the op is building a G60 16v  :rolleyes:
ABF cylinder head wins hands down IMO
has the best ports in std form not the biggest ports but they flow,  the early BIG port KR heads (027)  have big inlet porst but the exhaust ports are just f**king horrible.
all the VW's have gone bar 1.
« Reply #5 on: 12 August 2011, 13:23 »
Yes but will a ABF head fit on a G60 block :undecided:
Offline danny_p
« Reply #6 on: 12 August 2011, 21:26 »
yes it will.
g60 block is near as dammit the same as a KR block, some use fatter head bolts 1N ( i think ) but you can just drill out the head bolt holes in the head a littel if needed the PG uses same diamiter bolt as everythging else  just use 16v bolts.
obviously for 16v g60 you need diffrent pistons and iirc some or all g60 blocks will need a rebore to take 81mm pistons
« Reply #7 on: 12 August 2011, 23:51 »
yes it will.
Thanks for the info :afro:
Offline busterdub
« Reply #8 on: 13 August 2011, 17:42 »
yes it will.
oh excellent is there anything else that can be used from the abf???? as i have one to hand and any ideas were to get the pistons from?
Offline danny_p
« Reply #9 on: 13 August 2011, 19:12 »
audi s2
ive bought a complet S2 engine before thats lobed a rod and written it off to strip for bits to build an oldskool 16vt
