Author Topic: Best head for a g60 16v conv  (Read 3342 times)
Offline tshirt2k
  • Been there...Done that...
Re: Best head for a g60 16v conv
« Reply #10 on: 05 September 2011, 20:34 »
Just use the whole ABF engine.Reduce compression by using stacked gaskets or pistons. Better of using an eaton M62 as they are sheaper than a G60. But noisier, Unless you Change TB position.
Mk3 ABF 16VT Megasquirt V3
Offline danny_p
« Reply #11 on: 05 September 2011, 23:43 »
machene notches into 2ltr 8 valve pistons, fit them to the ABF block,  keeps the squish zone so can get more spark on without problems.
i prefer the M90 of the jag,  the charger lends itself to fitting quite well and bigger charger displacement means the cherger rpm can be droped reduceing noise and charge temps and makes it a bit more efficent.
STD abf manifold is best replaced with a custom log, shoule be abel to get one made for not to much money as there not that hard to make
all the VW's have gone bar 1.
