Author Topic: First gear issue  (Read 3800 times)
Offline Dilly
First gear issue
« on: 07 August 2011, 23:08 »
Hi guys,
Having trouble selecting first gear. Ive always had a little slack in the 'box but lost first gear the other day. The other gears are fine.
I had a look under the bonnet and just behind the engine I can see the linkage. There is a 'U' joint kind of shaft with what looks like a very worn bush. I'm guessing that this is the issue.
Any idea where I can obtain and how I can replace this bush? Ive had a look at the linkage repair guides but I'm not sure which part of the linkage this is.
Cheers.
Offline Seanl
Re: First gear issue
« Reply #1 on: 08 August 2011, 07:10 »
Dont think you can buy the bush separate, whole kit on eBay for around £25. I think it from tierod so should be decent quality anyway. Otherwise try gsf or ecp
