Author Topic: petral problems  (Read 2333 times)
Offline r0bster
petral problems
« on: 07 August 2011, 09:09 »
hey guys iv got a mk 2 golf 1985 wiv k-jetronic fuel system the fuel is not going thro the injectors so got new 1s coming bt is there any other symtoms why it mite not come thro injectors? low fuel pressureor anything?? please help guys b reg gti trying 2 return on the roaqd after 17 year sat in a garage.
Offline mk2bal
Re: petral problems
« Reply #1 on: 07 August 2011, 10:44 »
Firstly I'd check your spelling of petrol, then the lift pump in tank, then the main under car pump, then the metering head and lines, and finally the injectors. Have you pulled the fuel flow pipe to metering head off and proved fuel to there 1st, before ordering injectors?
Offline r0bster
Re: petral problems
« Reply #2 on: 07 August 2011, 19:42 »
sorry. yes i have replaced both pumps and the fuel is getting to the metering unit and thro the hoses into the injectors just not coing out the other side of the injectors.
Re: petral problems
« Reply #3 on: 07 August 2011, 21:02 »
Sounds like the injectors are blocked.
Offline Sam
  • Sam I am
Re: petral problems
« Reply #4 on: 08 August 2011, 11:14 »
Offline The Mighty Elvi
  • I'm better than you today.
Re: petral problems
« Reply #5 on: 08 August 2011, 16:17 »
Re: petral problems
« Reply #6 on: 08 August 2011, 23:56 »
Well what else can you say  :grin:
In a way he answered his own question.
Offline r0bster
Re: petral problems
« Reply #7 on: 11 August 2011, 20:20 »
the fuel is getting to the metering unit bt theres no fuel gettin to the injectors,looks like theres no pressure i have taken out the pressure valve changed the o rings and placed bk in bt still no pressure. sorry for any spelling mistakes not my number 1 thing on my mind ha ha
Offline Sam
  • Sam I am
Re: petral problems
« Reply #8 on: 11 August 2011, 20:31 »
Remove injectors and put em in a jar and try to fire her up. If they spray evenly you know your problem is engine related, if not its metering
Offline r0bster
Re: petral problems
« Reply #9 on: 11 August 2011, 20:52 »
nope its not coming thro the braded pipes without the injector on
