Author Topic: petral problems  (Read 2334 times)
Re: petrol problems
« Reply #10 on: 11 August 2011, 21:18 »
nope its not coming thro the braded pipes without the injector on
In that case the metering head is blocked.
One thing worth checking is to remove the banjo bolts on the metering head that feed the injectors and then check the small filters under each one.
« Last Edit: 11 August 2011, 21:20 by Wayne »
