Golf mk2
Advice on coil fitting, 16v model
Topic: Advice on coil fitting, 16v model (Read 1193 times)
walchy01
04 August 2011, 16:23 »
Afternoon all
Any tips on fitting an ignition coil... What to watch out for and what not to do's
Thanks
Walchy
The Mighty Elvi
I'm better than you today.
Re: Advice on coil fitting, 16v model
04 August 2011, 16:52 »
Disconnect the battery!
Then just pull of the spade connectors + HT Lead (remember where they go)
Undo the mount. Then fit the new one.
Simples.
walchy01
04 August 2011, 17:27 »
Sound, that reads easy, even to a novice like me... :embarassed:
Thanks
The Mighty Elvi
04 August 2011, 17:52 »
If you don't have a Haynes manual there's a PDF one in the maintenance section ^.
If your a bit unsure (its really a simple job) have a look in the section covering ignition. Theres a diagram for you to follow.
walchy01
04 August 2011, 18:01 »
Thanks will do
walchy01
04 August 2011, 21:13 »
Fitted coil, still sparking near king lead, thinking king lead is eeeerm knackered...
Change that tomorrow and see where we go from there...
Golf mk2
