Poll
how sto stop this from happening?????
help
1 (50%)
help
1 (50%)
Total Members Voted: 2
Voting closed: 05 August 2011, 15:16
Author Topic: engine cuts out at 5000rpm  (Read 1229 times)
Offline mikey_magic
« on: 02 August 2011, 15:16 »
My Golf gti mk3 will not rev over 5000rpm can anyone help??? :undecided:
Offline MK3 Menace
  • 98 GTI, big changes are coming...
Re: engine cuts out at 5000rpm
« Reply #1 on: 02 August 2011, 15:20 »
Hall sender or timing out?
Offline mikey_magic
« Reply #2 on: 02 August 2011, 15:23 »
thanks i look into this now, if it the hall sender do i need to change the dizzy?
« Reply #3 on: 02 August 2011, 15:36 »
Sounds like the timing is out and it is in safe mode.
Has it had a cam belt recently
Offline mikey_magic
« Reply #4 on: 02 August 2011, 15:39 »
when i got th car 3 months ago i changed the cam belt first before i even drove the car on the road :wink:
Offline VR6_Wherry
« Reply #5 on: 02 August 2011, 15:40 »
Then that will be the problem, timing will be out by a tooth. Get it checked out  :smiley:
VW BUSH
« Reply #6 on: 02 August 2011, 16:27 »
Set TDC and adjust the dizzy if out only a tooth or two, lot easier than taking it apart again :smiley:
Offline sychosis
« Reply #7 on: 03 August 2011, 09:16 »
As everyone else has said timing is out, I had this when I bought mine, had it serviced with a new belt and revving up to 6500 now  :grin:
Offline Len
« Reply #8 on: 03 August 2011, 13:07 »
Self inflicted! :laugh: :laugh: :laugh:
www.sas.org.uk
www.the-ace.org.uk
