Author Topic: CO AXIAL PARCEL SHELF SPEAKERS  (Read 2238 times)
Offline greenday95
« on: 01 August 2011, 12:46 »
Can i connect them directly to existing standard speaker wiring?
if so, HELP!!!!!!!!!!!!!!!!!!!!!
thanks
Offline dragonfly
Re: CO AXIAL PARCEL SHELF SPEAKERS
« Reply #1 on: 01 August 2011, 13:04 »
Assuming you are talking about using these speakers as a) you don't have any exisitng and b) the wiring is there - then yes you can connect them.
Offline greenday95
« Reply #2 on: 01 August 2011, 13:20 »
i have an x reg mk4 gti. want to put them into the parcel shelf.
could someone give me an idea how o do it as th reardoor speaker connection are different
Offline _Adam_
« Reply #3 on: 01 August 2011, 13:58 »
amp them :wink:
Offline dragonfly
« Reply #4 on: 02 August 2011, 11:46 »
So you want to disconnect the rear door speakers and add speakers to the shelf and use the exisiting door speaker connectors?
Don't ruin a shelf by cutting into it house speakers. Your best bet is to replace the fronts for better quality and leave the rear doors.
If you still want to put speakers on the shelf then either cut the connectors off the rear door speakers and attached a new length of wiring to the rear.  Or you can buy block connectors which attach to the existing connector and attach a length of wiring to the rear.
Offline Tazzy
« Reply #5 on: 14 August 2011, 12:40 »
i dont know about vws, but standard cabling is usually sh!te, so i wouldnt run a standard speaker and an after market more powerful speaker off one cable  :huh:
If It Comes Off, Modify It!
