Author Topic: Ferrari 355 brakes  (Read 7338 times)
Offline tech1889
  • Mk2 GTI FTW !!
Ferrari 355 brakes
« on: 27 July 2011, 00:30 »
Just surfing the web looking at brake upgrade kits for the good ol mk2.. This is probably not the best braking but it definitely scores some scene points and being a 4pot?? calliper will not exactly be bad for braking..
Can run 10.1 (256mm) up to a 12inch (205mm) disc which are all readily available.. in 4x100
Use an early 4x100 mk3 gti hub (1H2E)
Front and rear calipers are the same from what ive read so can get fronts or rears from a 355.. there is a pair in good nick for £200 on ebay atm.. to fit to the hubs all you need is a head bolt washer to align it all no need for caliper adaptors aslong as you get the callipers with the lugs not the radial fitment.. ferrodo do DS pads for them
Can run a minimum 15inch wheel so rm's are still possible  :wink:
This is the same calliper used in certain porsche's so they should be readily available
Just curious on peoples thoughts  :smiley:
« Last Edit: 27 July 2011, 09:54 by tech1889 »
Offline sprout99
Re: 355 brakes
« Reply #1 on: 27 July 2011, 07:21 »
280mm is biggest you can go and keep 15" wheels
i'm sure the biggest OEM brakes on 4x100 maybe 280mm anyway
355 is an awful lot of unsprung weight
280mm should be enough - i saw a big difference
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Re: 355 brakes
« Reply #2 on: 27 July 2011, 08:51 »
One of the best value conversion kits available: http://www.tsr-performancestore.com/tsr-big-brake-kit-for-mk1-golf-18-p.asp
285mm discs, they make a massive difference and fit behind 15" wheels all ok.
Offline tech1889
  • Mk2 GTI FTW !!
Re: 355 brakes
« Reply #3 on: 27 July 2011, 09:48 »
Ferrari 355 brakes not 355mm  :grin: Ibiza cupra is a 305mm disc  :nerd:
Offline tech1889
  • Mk2 GTI FTW !!
Re: 355 brakes
« Reply #4 on: 27 July 2011, 10:03 »
That quotes for a mk1 will that fit the mk2 ?
Offline SoundillusioN
Re: Ferrari 355 brakes
« Reply #5 on: 27 July 2011, 10:04 »
Don't know much on the matter but I must say would be great if you pull it off.
You'd have to make sure they were stickered up as Ferrari and that the wheels can show them off.  :grin:
Re: 355 brakes
« Reply #6 on: 27 July 2011, 10:08 »
Yes, and they work really well, I was working @ TSR when they were designing them.
Re: 355 brakes
« Reply #7 on: 27 July 2011, 10:08 »
Also what calliper do they expect you to currently have to use the extension brackets and make use of those discs?  MK1 calipers are small, hence why i'm rocking with Corrado ones.
Re: 355 brakes
« Reply #8 on: 27 July 2011, 10:29 »
The calipers are not the main issue, with a bigger disc you got more leverage if that makes sense, I know when I worked they we tried a std mk1 then fitted a 285 kit and the difference measured on a mot brake tester was a lot.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #9 on: 27 July 2011, 10:38 »
It seems simple to me but probably not so.. They are molded with a raised Ferrari writing would be awesome and can see them being better balanced..
