Author Topic: WIRING HELP!! - Audiobahn AW1251T  (Read 2818 times)
Offline DubSociety
« on: 25 July 2011, 19:34 »
Right, here are the specs:
Audiobahn AW1251T 12" subwoofer features:
    12" natural sound subwoofer with dual 4-ohm voice coils
    2 or 8 ohm operation
    400W RMS Power Handling
    1400W Max Power Handling
    Frequency Response: 24Hz - 1000Hz
    Efficiency 92.1dB
    Poly coated 2 layer non-pressed paper cone
    Non-pressed, Non-Transfer Paper cone
    2" 4-layer ASV Voice Coils
    PHAT Foam Surround
    Bumped and vented polished T-yoke
    KM3' Coated for virtually No Cone Distortion
    Multi-connect Lug Lock Terminals
    Chromed gasket and magnet mesh cover
    45 oz Strontium magnet
    Mounting dimensions - Depth: 5 1/4" Hole: 11 1/4" Diameter: 12 1/4"
THE PROBLEM I NEED SOLVING:
The subwoofer has 2 Positive Terminals and 2 Negative Terminals ... I haven't seen this before! ... I want a 2 Ohm Load to my Mono Amp which is 2 ohm stable providing 300w RMS, so I believe I connect, negative to negative, and positive to positive, and then run a wire from positive to the positive on the amp and a negative to the negative on the amp.
The thing is, each terminal has 2 slots ... so in total 8 slots, 4 for positive and 4 for negative ... do I run double speaker wires then to fill each slot? so 2 positives to 2 positive, and 2 neg to 2 neg etc?
Here's a pictue of the sub ...
« Last Edit: 25 July 2011, 19:36 by DubSociety »
Offline DubSociety
Re: WIRING HELP!! - Audiobahn AW1251T
« Reply #1 on: 25 July 2011, 19:52 »
Am I right in assuming wiring it up like this will be ok?
Offline B-chi
« Reply #2 on: 27 July 2011, 09:15 »
Yep. Both positives to positive on amp and like wise with negative will give you a 2ohm load.
