Author Topic: Nude Girls  (Read 3129 times)
Offline The Hoax
Nude Girls
« on: 12 April 2005, 23:48 »
Sorry Guys - Cheap attempt to gain attention!
I have a 1990 16v with a suspension kit ( I don't know the make but it cost several hundreds of pounds from Bedrock Veedub about 3 years ago.)
It is lower than standard and I suspect that the shockers are shorter. The rear rattles and is most annoying. I posted recently that the little washers that sit above the main upper bush had stress fractured allowing one shocker to pop through into the boot. I have now relaced both sides and it still rattles and its driving me crazy. The problem seems to be that the theaded portion of the shocker insert does not protrude enough for me to get the final nut on after the top bush is fitted. Rather than a flat main top washer, the kit appears to have a bucket washer, but the only way that I can get it all together is to turn the upper top bush upside down so that it is the ridged rather than plain side pointing upwards (sh!t description, I know). Please help as it is almost ruining my enjoyment of an otherwise lovely Oak Green Mk 2.
Thanks for any help pervs!
« Last Edit: 12 April 2005, 23:51 by The Hoax »
Offline Golfgal
Re: Nude Girls
« Reply #1 on: 13 April 2005, 00:13 »
Damn :wink:
V5 Beetle owner. I'm just here for the misfire threads....
Offline Mr Blue
Re: Nude Girls
« Reply #2 on: 13 April 2005, 00:20 »
have you tried puting some weight on the back so the shock pops up. then put the nut on?
had a siilar problem so i just removed one bucket washer and havnt had any problems yet. Dont refit the rubber topmount covers back. they squeek like a b!tch
and DAMN!  :grin:
« Last Edit: 13 April 2005, 00:24 by Blue Mk2 »
Judderi
Re: Nude Girls
« Reply #3 on: 13 April 2005, 14:34 »
I had a similar problem on the front with the bolt not sticking up far enough for the nut to go on. Not sure if the backs are similar but take your shocker off and make sure the top cap that holds the spring down is secured in the correct position. i had to wind it down loads which left just the right amount of threaded bar sticking though the stut top.
free
Re: Nude Girls
« Reply #4 on: 13 April 2005, 16:17 »
thats the best way while u put the nut ect on ,,,,,, but some gerth in the boot,
i to had the prob with the washer and it popin up,  :angry:
Offline The Hoax
Re: Nude Girls
« Reply #5 on: 13 April 2005, 17:12 »
Thanks a lot guys - I'll try weight in the boot first and if I don't succeed then I will strip and check.
Judderi
Re: Nude Girls
« Reply #6 on: 14 April 2005, 08:58 »
So it will be nude boy not girl! Yuk yuk
Offline The Hoax
Re: Nude Girls
« Reply #7 on: 14 April 2005, 20:38 »
Absolutely right Mk2GTI2.016v ! The job is going to be done bollock naked. Just need to make sure that I don't catch little Tommy the Todger on any thing sharp!
Judderi
Re: Nude Girls
« Reply #8 on: 15 April 2005, 08:27 »
 :cry: Argh get those nasty images out my head!  :cry:
*I bang my head against my monitor repeatedly
Offline CHR15
Re: Nude Girls
« Reply #9 on: 18 April 2005, 10:03 »
damn... no girls  :cry:
