Author Topic: Stupid question, will this mod fail an MOT???  (Read 4373 times)
Offline richandhazel
Re: Stupid question, will this mod fail an MOT???
« Reply #10 on: 12 April 2005, 14:40 »
Paul, I thought it was 1992, but I stand to be corrected. Has yours never had a cat, or has it been removed?
My 91 Polo has a cat fitted but when it packs up I doubt I'll replace it.........probably take a trip to powerflow :smiley:
« Last Edit: 12 April 2005, 14:42 by richandhazel »
Offline gibby
« Reply #11 on: 12 April 2005, 14:43 »
Yup Rich, you are right 1992 -----> http://www.dft.gov.uk/stellent/groups/dft_transstats/documents/page/dft_transstats_507875.hcsp#P397_15751
Here's the snippet -
1992
Speed enforcement cameras introduced at permanent sites.
All new goods vehicles over 7.5 tonnes to be fitted with 60mph limiters.
Minimum tyre tread depth of 1.6mm is introduced.
Catalytic converters fitted to all new petrol engined cars.
Toyota comes to Britain, producing cars in Derbyshire.
Mine never had a cat as far as I know, it was registered in December 1991 though.
......now officially dubless.
Offline MK4_20VT
« Reply #12 on: 12 April 2005, 14:44 »
Thanks guys 'n' girls, I'v Just to be able to find a Grill with the correct fitting clips for my mk2, it's quite hard as it think my slam panel is the same as an MK1????  :undecided:
« Reply #13 on: 12 April 2005, 14:47 »
1992
Ah yours is an early J, probably one of the last to get away without a cat then :smiley:
« Reply #14 on: 12 April 2005, 14:50 »
Be suprised if it is. Front end of a mk2 is very different to a mk1. Can you not remove all the front end i.e top panel, grill etc....to gain better access to the engine?
mix
« Reply #15 on: 12 April 2005, 14:53 »
i think anything mk1 0r mk2 doesnt have to have a cat because of its age......
« Reply #16 on: 12 April 2005, 14:57 »
I just had it in my mind that a J plate should have a cat. Obviously that is the cut off year and later J plates will have one.
Offline gibby
« Reply #17 on: 12 April 2005, 14:57 »
Mix, some mk1 cabs and mk2s were K (92/93) and very, very rare but they also did mk1 cabs on L reg (93/94) so they may have needed a cat if introduced after 1992, whether that means registered or built after 1992 to need a cat, I'm not sure.  :undecided:
Offline MK4_20VT
« Reply #18 on: 12 April 2005, 15:08 »
My grille has 2 large clips on top which secure it to my slam panel, were the later grills i'v seen have smaller clips on the top which fit into the slam panel???? HELP
Offline Horney
« Reply #19 on: 12 April 2005, 15:08 »
CATs "should" be standard fitment on anything J plate and above if sold in the UK. They "Should" be fitted for an MOT, but if you're car can pass the emissions without it they probably won't notice.
Nick
