Author Topic: Mk2 16v Turbo Full car rebuild  (Read 92502 times)
Offline DanChave
Re: Mk2 16v Turbo Full car rebuild
« Reply #90 on: 23 November 2011, 08:09 »
Amazing work on the leather... not often you see work like this on here..  Only noticed a similar thread once where repair work was done and then re-coloured from grey to tan.. before then I didn't really think this kind of work was possible.
You cant find that thread can you? I would be interested to have a read!
Offline Neo Badness
  • Feet are for pedals
« Reply #91 on: 24 November 2011, 00:57 »
Offline DanChave
« Reply #92 on: 24 November 2011, 08:57 »
that video is crazy! No luck on that thread then?
Offline tomp
« Reply #93 on: 30 November 2011, 19:08 »
Thanks for all the positive comments on the seat repair, it turned out really well...
Just a quick update, just been sanding, sanding and more sanding. Found a little more filler work is needed but nothing major.
If anyone has a spare drivers side wing mirror for a mk2 then I may be interested (I may have another somewhere), found the one I took off months ago smashed...
Offline tomp
« Reply #94 on: 30 November 2011, 19:15 »
Some inspiration to keep you going :smiley:
http://www.youtube.com/watch?v=a0TFPMgKmvQ&feature=related
If it really is 58psi of boost (4 Bar), that's insane!
Offline Neo Badness
« Reply #95 on: 01 December 2011, 10:46 »
That's a bugger about the mirror.
58psi ftmfw :laugh:
Are you going to fit a limited slip diff'?
Right, I'm off to go and do something useful...
Offline Sam
  • Sam I am
« Reply #96 on: 01 December 2011, 14:49 »
58psi ftmfw :laugh:
The 16vt is borderline needing an LSD, I would like one but dont need one.
Offline tomp
« Reply #97 on: 01 December 2011, 22:36 »
No LSD, my car used to eat gearboxes, I blew the diff pins in a couple of boxes, then got a box rebuilt with bolted diff and that only lasted a bit longer than a standard box (and cost about 10x as much!). Then went with a mk3 box and its been ok for longer than all the other boxes put together. Famous last words!!!
What clutch do you run caistor_bmx? Mines a Helix Autosport . What's happening with your Golf now?
Not too fussed about the mirror, they are cheap and plentiful enough for it not to be a problem....
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #98 on: 02 December 2011, 14:48 »
Great Thread.... Just read it all the way through & Will keep looking at new posts...
Keep up the great work!!
For More Info Click To See;
Offline tomp
« Reply #99 on: 04 December 2011, 11:42 »
Cheers Ken
I haven't been able to spend as much time on it recently as I would of liked because of work but it will get there....
