Author Topic: indicators constantly on  (Read 1953 times)
Offline lockey
« on: 12 July 2011, 21:49 »
after engine conversion indicators are now constantly on and lights aren workin  :sad: what could be causin this
Offline Malz0r
  • Haters gunna hate.
Re: indicators constantly on
« Reply #1 on: 12 July 2011, 22:10 »
Earth on the fusebox? Had a similar problem on an engine swap in a Honda!
Offline lockey
« Reply #2 on: 12 July 2011, 22:14 »
what yo mean that there an earth missin from fusebox to body??
Offline Malz0r
« Reply #3 on: 12 July 2011, 22:16 »
Yea I totally forgot to do the earth on a Honda an when you flashe the head lights the indicators would come on instead! As soon as I put the earth back on it all worked perfect!
Offline lockey
« Reply #4 on: 12 July 2011, 22:28 »
alright lad sound il have a look tommorrow
Offline Adam
« Reply #5 on: 12 July 2011, 23:49 »
What engine did you fit? What year is your car and what year was the engine? Did you reuse the same loom or did you change it?
Down Hill From Here.
Offline lockey
« Reply #6 on: 13 July 2011, 12:37 »
eh fitted a 95 1z tdi engine into a 97 8v gti and changed the wiring from fusebox forward ie front lights indicators engine loom etc
Offline wade1981
« Reply #7 on: 13 July 2011, 21:57 »
Lockey, I'm picking up my 96 tdi on sat. Goner run it for a few months then do what you have done put the tdi lump into my 96 gti 8v which is mint. Figured a tdi will be a much better than the weak 8v.
Got any tips?? Did you use your gti fuel tank? Have you got A/C?
Offline lockey
« Reply #8 on: 14 July 2011, 15:55 »
Yeah ya will have to change accelerator pedal if it doesnt have the mounting for the drive by wire on it which involves removing dash and heater matrix and ya may change cable gear linkages from tdi into the gti and swap over the hydraulic clutch cylinder and wiring from fusebox forward and use the tdi front end with radiator and that
Offline tweed
« Reply #9 on: 14 July 2011, 16:32 »
why are you doing this? you got a mint gti so your fitting a tdi engine?
why don't you just have two cars? doesn't make sense
