Author Topic: car only starting when manually injecting fuel :)  (Read 1818 times)
Offline Bigdunc
Hi guye been having problems with car recently, we have done a recent head rebuild and were struggling to get car to star.
We have finally got car to start but it will only start if you manually inject fuel in to the throttle body. The injectors are injecting but for some reason the car wont start with just them alone.
I have been reading up and seen that some people have had problems with a faulty ECU and it messing up the way the injectors work. I have managed to get a new ECU to try tomorrow.
If this solves the problem then GREAT NEWS But if not what do i then start to look for??
Fuel Pump / Relay
Fuel preasure regulator
Air flow meter
injectors
Offline mk2bal
Re: car only starting when manually injecting fuel :)
« Reply #1 on: 12 July 2011, 20:10 »
You need spark compression and fuel. You have fuel. Check spark and compression + air leaks, if it all worked before taking it apart. Guessing its an 8v digi?
Offline Bigdunc
« Reply #2 on: 12 July 2011, 20:57 »
Yes it's 8v digi, have compression just only wants to start when manually feeding fuel
Offline Benrevs
« Reply #3 on: 12 July 2011, 21:36 »
Can you hear the fuel pump buzz when the ignition is on?
Offline danny_p
« Reply #4 on: 12 July 2011, 22:58 »
if the fuel pumps run,    check the injectors are getting 12v
all the VW's have gone bar 1.
Offline danny_p
« Reply #5 on: 12 July 2011, 23:02 »
steady up scrap that.    change of plan,  you've had the cyl head off....
take the fuel ines off the fuel rail and swap them over   sounds like there on the wrong way round.     if your trying to shove fuel up the outlet of the pressure reg it ain't going to go
Offline Bigdunc
« Reply #6 on: 13 July 2011, 00:31 »
The injectors are doing something, only 1 fuel line come off while head off kept the other attached to the fuel pressure regulator, it seams like the injectors are flooding or not responding as they should, fuel is getting through so doubt it's fuel pump but possible.
« Reply #7 on: 13 July 2011, 13:51 »
Could be a blown ecu, do you refit all the earths as required.
Offline Bigdunc
« Reply #8 on: 13 July 2011, 22:08 »
changed ecu and the air flow meter head and mooved the dizzy and she starting :) just gonna have to run her for a week with her tuned my ear till i can get a gun to her :)
