Author Topic: dobby: project mk2 vr6 conversion... 90% done!  (Read 91113 times)
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
Re: dobby: project mk2, vr6 retro wagon!
« Reply #120 on: 23 November 2012, 21:25 »
bought myself another little goody, corrado steering wheel!
Offline BISSONE
« Reply #121 on: 23 November 2012, 22:17 »
Think thats from a Polo GT pal not a corrado. May be wrong though.
Offline andynorfolk
« Reply #122 on: 24 November 2012, 18:12 »
i later found out they are the same aha
Offline andynorfolk
« Reply #123 on: 07 September 2013, 23:32 »
so my polo got written off a couple of weeks ago so i need to get this back on the road as my daily :)
here's a few pictures of progress today :P
mk3 vr subframe cleaned up and painted ready to go on
gti brakes removed
new ibiza cupra set up compared to the old gti brakes
fitting passat b4 tdi master cylinder
f*ck steering rack bolt on the old sub frame
moving the old girl inside
oh hello vr
subframe built up and ready to go on
engine ready to go in
the lads fitting stainless mani and subframe
tightening the mani up
fitting the subframe
engine all bolted in
as she sits tonight, brake set up fitted and engine bolted in
any comments welcome :)
« Last Edit: 07 September 2013, 23:47 by andynorfolk »
Offline DanChave
Re: dobby: project mk2, vr6 retro wagon... finally some progress!
« Reply #124 on: 08 September 2013, 07:42 »
Nice to see some progress in this, it'll be good to see the finished article :)
Offline andynorfolk
« Reply #125 on: 08 September 2013, 22:34 »
so today we had a lot more progress :)
first of all i managed to get my corrado pedal box fitted, and managed to bend and rivet the top bracket to hold it secure
got my momo boss and 280mm momo wheel on
got the engine back out as i needed to dent the chassis leg to give clearance for the bottom pulley on the engine, also had to drill and flatten the bulkhead to take the clutch cylinder
then got all the front suspension and brakes properly fitted and bolts and brake lines all tightened and engine back in
also removed the heatshield and mk2 gear shift tower and linkages but didn't get a picture of that!
have just bought a mk3 vr shift tower and cables and a mk2 1.3 accelerator cable :)
will have another night during the week on her so i know exactly what bits i have left to get then will be hitting it hard again next weekend to try and get her running :D comments welcome!
« Last Edit: 08 September 2013, 22:52 by andynorfolk »
Offline notenoughtime
Nice work!!!
Offline andynorfolk
don't you just love car parts?!
1.3 mk2 throttle cable, oil, oil filter, sump plug, spark plugs, vr6 shifter and cables, shifter linkage kit (which looks an utter b1tch to fit!) and my polished oil catch tank :)
i also am awaiting delivery of dobby's new shoes :P
will be spending another solid weekend working on her and hope to get her pretty much finished, only problem i have come across is i thought i had a later ce2 loom and fusebox but i don't! luckily my mate is a wiz with wiring and reckons he has all the bits to sort it! :D
comments welcome guys...
Offline andynorfolk
so i may have got a little carried away tonight and just bought a full front poly bush kit, 10mm high energy ht leads and i'm currently the highest bidder on a set of engine plastics! :P
Offline andynorfolk
so today i got a lot more done! :)
my mate welded in a new rear arch and sorted round my rear tow eye and a small spot on the other rear arch!
then i got the vr6 shifter and cables fitted, drilled holes for the front two brackets and fixed them with a nut and bolt, then fitted the rear with metal self tappers and then fixed from above as well with my home made bracket :)
and all fitted
gave the engine a good service apart from plugs and leads as they haven't arrived yet!
then i noticed this :/
i'm guessing there's meant to be a cover that fits to the side of the gearbox covering the flywheel?!
then i got the corrado slim twin fan rad fitted with another home made bracket and bolted the new wings and front on :)
and that's how she currently sits tonight, will be spending another full day on her tomorrow!
