Author Topic: Dom's Mk4 Story So Far - it's all over!  (Read 439498 times)
Offline dom
  • Back in a Mk4
Re: Dom069 - My Mk4 Story So Far...Lampshade content
« Reply #1170 on: 16 June 2013, 16:31 »
Attacked the SAI this morning, drained coolant and started taking it all apart:
Rocker cover gasket was leaking a while ago and made a bit of a mess:
Cleaned it up:
Fitted blank:
Combi valve and hardlines removed:
Removed the pump and bracket, then removed the carbon canister:
All back together:
Need to order a couple more resistors then I'll get rid of the lower engine cover and N249/N112 valves, then a catch can is next up :cool:
Offline Kye22
« Reply #1171 on: 16 June 2013, 21:35 »
Wow great looking golf dom. Top dedication in your efforts to do things properly. Too many chavvy golf's and r32 fiberglass reps about atm.
Must say did preferences the anniversary rear though, but each to there own.
Did u have and problems with sump catching while that low
Are them joms really.that cack?
Offline dom
  • Back in a Mk4
« Reply #1172 on: 16 June 2013, 22:04 »
Cheers :cool:
I did like the anni rear but I wanted to show off the Milltek :grin:
The sump has some very minor scratches on it but it very rarely catches, as long as you take speedbumps slowly it's fine!
JOMS are a cheap way of lowering your car, in that respect they work very well. The ride when you're lowered 40-50mm is not bad at all, but any lower than that it is crashy and bouncy. The biggest gripe that I have with them is how poorly they have lasted, one front shock started leaking a few months after fitting them and one of the rears is leaking now.
Offline Kye22
« Reply #1173 on: 16 June 2013, 22:18 »
Think i'llsteer clear of them then  :laugh:
Funds are restricting me so riding on 40mm lowering  springs at min with anni shocks
But still looks like a tractor even with 18"s on
Offline dom
  • Back in a Mk4
« Reply #1174 on: 29 June 2013, 21:21 »
Again, not much to update. Had some neoprene tubing lying around so bodged together a cold air feed:
Deleted N249/N112 valves and the panel they were attached to as well as lower engine cover:
Started to give the engine bay a clean:
I can't wait to have a powder coated inlet manifold and rocker cover, they've been bought just need to get them coated!
Offline golfyste
  • Project track car
« Reply #1175 on: 29 June 2013, 21:25 »
Looking good dude  :cool:
Starting to look very tidy with the deletes! The head and mani will be a nice edition!
Ps. Where is you get your sk2 filter, gsf?
Offline dom
  • Back in a Mk4
« Reply #1176 on: 29 June 2013, 21:36 »
Yeah, catch can next, might look into relocating battery to the boot as well.
I got it from Baxxy but it was brand new, it was in a ECP box :wink:
Offline golfyste
  • Project track car
« Reply #1177 on: 29 June 2013, 21:40 »
Awesome  :cool:
Offline dom
  • Back in a Mk4
« Reply #1178 on: 01 July 2013, 22:40 »
Finally got round to sanding down all my net optic trim :grin:
Doesn't look too bad tbh! Much better than the carbon wrap that was on before!
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #1179 on: 01 July 2013, 22:58 »
Agreed looks alot better  :wink:
Golf Gti
