Author Topic: So I put gearbox oil in the plastic cap that looks like the filler hole!  (Read 8544 times)
Offline rizzel
As said I have stupidly put a litre of oil in this hole... only to find out later that this actually isn't the where to fill up the gearbox!
Two things... Am I going to get massive clutch problems now??? and would this be why all the oil came pouring out the bottom of the car, or do I have a leak somewhere??
Thank you :(
Offline earlymk2
You will most likey have clutch issue, that hole is for the timing. It is also why the oil came out too!!  :undecided:
Offline rizzel
thats not too bad then.. I would much rather buy and new clutch than have to get a new gearbox fitted, thank you :D im more happy now lol
Offline pigbladder
id prob dose a load of carb /brake cleaner down there and hope for the best
next time the gearoil goes inside the gearbox not the bellhousing  :wink:
Offline Thom89
  • Looking for an "Icebreaker"
OOOooops wheres my Mr Magoo pic!
Thom
Offline Thom89
Found it!
Thom
Offline Sam
  • Sam I am
Classic. Did you not wonder why your gearbox filler cap was a. plastic and b. had a hole in it  :lipsrsealed:
Fail  :grin:
You may get lucky with the clutch but it will not have done it much good.
Offline rizzel
I did wonder this yes.. but the picture in the haynes manual isnt the greatest of help and from what I could gather from that, I was putting it in the right place..   :huh:
oh well I have no learnt my lesson :D
Offline SoundillusioN
I cant help but  :laugh:  Sorry.
Closest I've come to this was an emergency oil change many years ago, so stressed and tired I forgot to put the sump bolt back in and filled the engine back up with oil.. Obviously all of it ended up draining straight back out again on to the floor!  :rolleyes:
