Author Topic: TDI's how many models were there? spec? etc, please help...  (Read 13778 times)
Offline sprout99
Re: TDI's how many models were there? spec? etc, please help...
« Reply #20 on: 27 July 2011, 13:10 »
Quote
I would say the 130 is the best all rounder. Don't suffer from camshaft wear quite as much, higher torque than the 150 and less boost pipes to blow off.
the 130 is the better engine but very peaky compared to 150
i've had both and the 150 has a noticably longer torque curve but 130 is more eager
It's not a better engine, its the same engine basically.
Better torque curve means nothing after a remap
better choice is what i meant
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Kerrse
« Reply #21 on: 27 July 2011, 13:52 »
Quote
Not sure why you think they are a better choice the 150 is a great engine, never had any problems with mine and it has done 125k, i have owned it for 4-5 years.
Offline sprout99
« Reply #22 on: 27 July 2011, 13:59 »
more of them to chose from ...... wider use in VAG range
I've go the 150 now - i think it's great
now as frugal as the 130 but goes like a train
I'm not scared of cam probs / turbo probs etc I kow car will be serviced right
using correct spec oil.
Some say that the 150 doesn't map as well.....how?
bigger turbo and injectors and FMIC.
The weak point there is the clutch is same 240mm unit used in 130pd.
My car apprently has a mild remap (clutch friendly) It kept up with a heavily mapped Ibiza
cupra Tdi and didn't smoke like a tug boat
Oak green mk2
V50 D5 Sportwagon
Offline Rhyso
« Reply #23 on: 27 July 2011, 14:10 »
Injectors are the same I believe
You get more bhp out of a 130; upto 50bhp in some cases whereas the 150 tends to make about 30-40bhp
Also the 130 tends to make more torque; most of the 150's seem to struggle to make over 300lbs ft torque  :undecided:
Certainly the 170 engine in my Audi doesn't produce as much torque as my old 130 and the driving experience is very different.
Offline sprout99
« Reply #24 on: 27 July 2011, 14:25 »
so basically they end up the same ish after map. but smaller turbo spools faster so feels quicker
i had an octavia VRS Pd- i didn't thnk the map made much difference
130pd's do map very well. Had 3 ........in past
Oak green mk2
V50 D5 Sportwagon
Offline Rhyso
« Reply #25 on: 27 July 2011, 14:27 »
With a 170 engine??
Mine has certainly made a difference; more urge lower down and a very strong top end  :evil:
Offline sprout99
« Reply #26 on: 27 July 2011, 14:38 »
had a 140 dsg and a 170 manual both remapped
just not impressed by the oil drinking 2.0 tdi. PD
Oak green mk2
V50 D5 Sportwagon
Offline Rhyso
« Reply #27 on: 27 July 2011, 14:50 »
I've had to top mine up on a couple of occasions; will be interesting to see how it fairs as its been switched from longlife to time & distance
Offline Kerrse
« Reply #28 on: 28 July 2011, 16:07 »
I would never run a car on longlife ..defo worth changing the oil & filter every 10k max
Offline Rhyso
« Reply #29 on: 28 July 2011, 16:13 »
Didn't have a choice with the Audi as I wasn't the first owner lol.  It only had 1 service in 24,000 miles before I bought it  :shocked:
