Author Topic: top strut mounts  (Read 897 times)
Offline reptiles nd fishin
top strut mounts
« on: 04 July 2011, 19:02 »
I appoligise if this has been asked already but i need a quick answer.
How do you undo the top strut mount? i have removed the two bolts that go through the hub but now i have to drop the struts, i have done it on many fords which have the three nuts and bolts holding the strut up but on my golf the is only the 22mm nut with the allen key but i am a bit wary because isnt that holding all the tension in the spring?
Or is there another nut under that one?
Again sorry if this has already been asked.
« Last Edit: 04 July 2011, 19:18 by reptiles nd fishin »
Offline golf newbie
Re: top strut mounts
« Reply #1 on: 04 July 2011, 19:23 »
If you mean the nut above the cup thingy in the engine bay.
There is another nut under that holds the tension.
« Reply #2 on: 04 July 2011, 19:27 »
Cool cheers, i thought that but didnt want to just go ahead incase i send another socket into outerspace. (learnt that one the hard way,lol)
Offline golf newbie
« Reply #3 on: 04 July 2011, 19:30 »
LOL.
« Reply #4 on: 04 July 2011, 20:15 »
Yes you have another nut, you will also need spring compressors to release the main top nut.
« Reply #5 on: 04 July 2011, 20:56 »
Do you mean the nut above or bellow the strut mount?
I have spring compresors done a few suspensions before just never on a VW
« Reply #6 on: 04 July 2011, 20:58 »
The one that holds the top mount on, the one under the bonnet only holds the top plate.
« Reply #7 on: 04 July 2011, 21:01 »
Cheers mate :smiley:
