Author Topic: Cambelt moves side to side!!!!  (Read 3662 times)
Offline Big Tone
« on: 04 July 2011, 16:38 »
Found the cause of my squeak!
A tiny bit of anti-slip on the belt and its sweet.
I can see the profile of the belt move about 1-2mm across the pulley. This syncs up with the squeak.
Tension is ok, alignment is fine, everything is located correctly and torqued up.
Any ideas? Suggestions how I may fix it.
Without a new belt our spraying belt spray on it every week.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline AudiA8Quattro
Re: Cambelt moves side to side!!!!
« Reply #1 on: 04 July 2011, 16:48 »
Did you change water pump, tensioner?
How do you know the belt tension is spot on, could it be a tad tight?
Offline Big Tone
« Reply #2 on: 04 July 2011, 17:42 »
waterpump,tensioner and idler pulley all replaced.
True, it could be a tad tight, but whats the best way of relieving this?
back off the tension using a bolt and reapply?
« Reply #3 on: 04 July 2011, 18:29 »
Yes you could give it a try.
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 04 July 2011, 21:57 »
the belt ment to twist 90 degs
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Big Tone
« Reply #5 on: 04 July 2011, 22:20 »
« Reply #6 on: 04 July 2011, 22:42 »
On the longest run of the belt, grab it with your finger and thumb, how much can you twist it?
Offline Big Tone
« Reply #7 on: 05 July 2011, 08:30 »
I see, can twist 90 degrees, same principle as 15mm deflection.
Tension is fine, noise comes back after a few days very faintly, a LITTLE bit of anti slip and the noise goes away.
Done 2500 Miles+ since cambelt change, so no problems there.
Doing my nut in.
« Reply #8 on: 05 July 2011, 10:07 »
I would say either the water pump, tensioner pulley bearings are a bit noisey, or you need to back the belt tension off ever so slightly.
Was the job done at a garage? parts from the dealer?
Offline javalin
« Reply #9 on: 05 July 2011, 10:48 »
+1
90 twist should be "reasonable" force, not finger breaking force.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
