Author Topic: Cambelt moves side to side!!!!  (Read 3663 times)
Offline Big Tone
Re: Cambelt moves side to side!!!!
« Reply #10 on: 05 July 2011, 14:11 »
I would say either the water pump, tensioner pulley bearings are a bit noisey, or you need to back the belt tension off ever so slightly.
Was the job done at a garage? parts from the dealer?
Gen parts, DIY though.
Twist force is reasonable, nothing excessive.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline AudiA8Quattro
« Reply #11 on: 05 July 2011, 14:50 »
Try backing off the tension very slightly.
Offline Big Tone
« Reply #12 on: 05 July 2011, 16:37 »
Will do. Nice one
Offline WadGTI
  • Golf GTI'er
« Reply #13 on: 05 July 2011, 16:47 »
Oil too think perhaps?
I forgot to change my oil in one of my old cars in 2 years and the tensioner came loose which cause the timing chain to rattle inside the engine. no damage was done to the valve - but the oil was pretty think - I was sure this was the culprit.
Offline Big Tone
« Reply #14 on: 05 July 2011, 18:51 »
Nope, 5w30 3 months old.
sump and rocker cover removed and cleaned
Chain tensioner its fine
Pick up pipe and oilways cleaned
Its definitely the belt.
