Author Topic: Car health check  (Read 3069 times)
Offline stu646
Car health check
« on: 04 July 2011, 14:20 »
How much does a garage usually check for one of these?
Just want the car checked over to see what works needs doing either now or later on in the future.
Offline Jack3559
Re: Car health check
« Reply #1 on: 04 July 2011, 14:21 »
Ignorance is bliss!
Offline stu646
« Reply #2 on: 04 July 2011, 14:26 »
Ha, just have a annoying sound in the car and have no idea what it is , so hopefully the check might bring some results up.
Offline SoundillusioN
« Reply #3 on: 04 July 2011, 14:43 »
Meh... depending on where you took it I wouldn't trust it, next door neighbour went to ford for something similar and they tried to blag a new engine out of her!
What kind of noise and roughly where?
Offline dom
  • Back in a Mk4
« Reply #4 on: 04 July 2011, 14:44 »
Id only get a health check done at a garage I completely trust, otherwise you might find yourself with a hefty bill for necessary work :wink:
Offline stu646
« Reply #5 on: 04 July 2011, 14:48 »
It is a whining/squealing sound, which seems to be coming from the front , near the passengers side I think. Although is hard to pinpoint it.
The noise itself only happens when I have been in the car for a longer journey ( 30 mins or more ) never on a shorter journey. Also the noise does not get worse with the brakes being applied and happens even when I do not use them, so it is not the brakes.
It only happens when slowing down from 20mph downwards. It will start off quite then after about 4/5 times of slowing down the noise will get louder.
If say I stop though, even for 5 minutes with the engine off, I can then drive again for about 20 minutes without the noise happening.
Offline Jack3559
« Reply #6 on: 04 July 2011, 14:50 »
Wheel bearing.
Offline stu646
« Reply #7 on: 04 July 2011, 14:52 »
Really? Would it not make the noise all the time though?
I am not that mechanical minded though so go easy on me!
Offline Jack3559
« Reply #8 on: 04 July 2011, 15:17 »
Nah, mine has intermittent when I had faults.
Usually it was alright when it was cold and then after a short while, it'd kick in and get really loud.
Noise changes under load, i.e. when braking.
Offline stu646
« Reply #9 on: 04 July 2011, 15:19 »
See I always thought it would make more noise when I was driving at speed, not when slowing down.
Oh well, should hopefully cost no more than what £120 odd ? Could even get my own wheel bearing kit from offline and get a garage to fit it couldn't I, might save some money
