Author Topic: what have they done  (Read 1722 times)
Offline jay12345
what have they done
« on: 30 June 2011, 07:18 »
Any advice would be welcome.Car went to garage and had bottom hose housing changed,oil and filter and gearbox oil changed and has come back with faults.Abs light comes on after you reach about 10mph.Theres a misfire and it now sound really tappety like a diesel.cheers for any views.jay
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: what have they done
« Reply #1 on: 30 June 2011, 09:05 »
What car/engine?
 01455 617233
Offline Big Tone
« Reply #2 on: 30 June 2011, 09:34 »
Take it back! :laugh:
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline jay12345
« Reply #3 on: 30 June 2011, 09:53 »
A agu 1.8t.Its back at garage at moment.Just dont want them to try and shaft me.Abs light no longer comes on after i fiddled around by the pump.I changed the maf and cleaned up the ignition amflifier but it still runs like sh!te.Doesnt seem to have lost power when driven hard but the sound on tickover is appalling.Been popping a bit and smells a bit rich when idling.cheers jay
Offline jay12345
« Reply #4 on: 30 June 2011, 10:02 »
oh yeh its a golf :smiley:
« Reply #5 on: 30 June 2011, 11:06 »
Well it sounds like they have done something so they should sort it.
Offline jay12345
« Reply #6 on: 30 June 2011, 20:05 »
They have now said the the top end is getting starved of oil and there is likely a blockage.They would take off the sump and rocker cover to find the blockage because it is internal.I can understand this because of the tapping but the misfire was found immediately after an oil change.I dont think they have a f**kon clue what is wrong.They can look at it monday.Wonkers.cheers jay
« Reply #7 on: 01 July 2011, 00:18 »
That will be your oil pump pick up pipe blocked, cheap and easy to sort.
Offline jay12345
« Reply #8 on: 01 July 2011, 04:31 »
would this cause a misfire tho.Where is the pick up pipe located,I might give it a try this weekend,cheers jay
Offline carlitto7
« Reply #9 on: 01 July 2011, 13:20 »
You need to remove the sump to clean pick up pipe not that hard to do
