Author Topic: 99 1.8T Gear Change Spinning whoooose Noise  (Read 3097 times)
Offline m4nesh
« on: 08 April 2005, 16:17 »
Hello Chaps
Need some help...
Driving to and from work in my '99 1.8T I noticed under acceleration when I change gears (at the point when you push the clutch down) there is a noise which sounds like something not spinning freeley coming from underneath th car.  Its a kind of whoooooose noise but you can make out its something not spinning freely.  Anybody had a problems similar?
Just hope its not expensive :cry:.  I have noticed it doesn't happen when slowing down or or go down through the gears.  Any feedback would be much appreciated.
Offline Gulfstream11
Re: 99 1.8T Gear Change Spinning whoooose Noise
« Reply #1 on: 08 April 2005, 16:33 »
Describe "WHOOOOOOOSE"...Cos I had a "WHOOOOOSH" type noise on my 2000 1.8t while changing up thru the gears.Kinda like if u flap your finger in front of your mouth as you whistle.Anyway,took in into the stealers and it cost me £54.worn turbo valve or summink,cant quite remember but it was important it was fixed.. :huh: this was after 20,000 miles tho..cheers
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #2 on: 08 April 2005, 20:39 »
dump valve?????????????
Offline m4nesh
« Reply #3 on: 08 April 2005, 23:46 »
Gulfstream11 u got the noise in one... thats exactly it.
You think its a worn turbo valve? any chance could give me more info?
Regards
« Reply #4 on: 09 April 2005, 11:43 »
OK dude listen up..I took the car straight into the dealers and apparently it was £54 worth spending.So I suggest u get straight to it.The bumpf for my old Golf is around somewhere so I can't give you the exact terminology..
Quote
Could be Gaz but is that what the part is called?.I thought that too but the dealer called it something else! :huh:
Offline Ryan_s3
« Reply #5 on: 09 April 2005, 21:45 »
Sounds like a knackered dump valve.Replace with a standard item for £15 for vagparts.com. The noise is the air hitting the back of the standard dv that is not opening(knackered).Will wear out the turbo alot quicker.
Offline m4nesh
« Reply #6 on: 14 April 2005, 09:19 »
went steelers and they charged me 60 squid to change the dump valve..... assholes
anyways thanks for the help with this
Offline GazB
« Reply #7 on: 14 April 2005, 09:43 »
60 squids, wtf. :angry:
You could have got a forge or bailey item for an extra 20-30 :sad:
« Reply #8 on: 14 April 2005, 20:48 »
Its gone up £6 since I had mine done :huh:....So has the "WHOOOOOOOOOSE" gone now???  :smiley:
Offline m4nesh
« Reply #9 on: 18 April 2005, 13:12 »
WHOOOOOSE gone now but bet I'll find some other noise thats gona cost me!  :huh:
