Author Topic: MK1 cabby currently 16inch alloys, thinking of 17's  (Read 7452 times)
Offline OldRic
Currently have 16inch TSR alloys with 195/45, did have 205/45s but they ended up rubbing when cornering hard, car has been lowered 30mm
I was thinking of putting 17inch alloys on but am worried about them rubbing. Am i correct in thinking that even if the the tire profile is less. i.e. 195/40 or 205/40 the overall diameter will still be greater than 16s with 195/45?
Does any body currently run 17's on a MK1 cabby that has been lowered?
I had to have the rear arch ground down to stop the 16s rubbing, they very occasionly still catch if i have a lot of weight in the back and it bottoms out.
Re: MK1 cabby currently 16inch alloys, thinking of 17's
« Reply #1 on: 28 June 2011, 23:46 »
17"s are too big on a mk1, stick with 16"s  :smiley:
Offline SoundillusioN
« Reply #2 on: 29 June 2011, 09:28 »
You've answered your own question really as I'm not sure why you would want to increase the wheel size on a car that struggles to where 16" as is it.  To be honest in my opinion, MK1's are ruined by big wheels, Max size to get it low and still be a decent drive is 15". 17" will make it look like a rollerskate!
Offline Guy
« Reply #3 on: 29 June 2011, 18:05 »
not a good idea really... would be impractical, and look gash
even done well it looks wrong...
get just the right size rims and everything falls into place  :smiley:
« Reply #4 on: 30 June 2011, 09:35 »
^^^^^ And that looks like a set of 16s and is the limit...  MK1's can roll on their original wheel size of 14" and still look great and will still drive superb.
Offline shepgti
« Reply #5 on: 30 June 2011, 09:56 »
15's are by far the best size for any mk1
« Reply #6 on: 30 June 2011, 10:19 »
Couldn't agree more, mine on 15's
Offline lemski
  • 16v
« Reply #7 on: 30 June 2011, 10:22 »
17s r big on a mk1. I wouldn't even put em on a mk2
Offline Guy
« Reply #8 on: 30 June 2011, 21:49 »
+2
mine on 15's
Rivage by Guy Frankland, on Flickr
Offline OldRic
« Reply #9 on: 01 July 2011, 19:55 »
Thanks for the advice, i will avoid 17s, will stick with 16s  or look at 15s if they will fit over the front brakes.
I have large disk conversion, so i dont think 15s will fit.
