Author Topic: My Mk3  (Read 76012 times)
Gavv8
Re: My Mk3 (The lifer)
« Reply #70 on: 11 February 2013, 19:31 »
Cheers Dan!.. the arches will be coming off in the summer when i do the rest of the paintwork.
Offline DanChave
« Reply #71 on: 11 February 2013, 19:34 »
:D Good lad!
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #72 on: 11 February 2013, 21:03 »
I really like the arches look! gives it definition, i think you should keep em on!  :evil:
Gavv8
« Reply #73 on: 11 February 2013, 21:06 »
I like them on too but getting rid of another rust trap is part of the road to mk3 happiness.. :grin:
Offline DanChave
« Reply #74 on: 12 February 2013, 13:14 »
'Like'
Lol, sign of a someone who truly understands mk3 ownership!
Gavv8
« Reply #75 on: 25 March 2013, 21:34 »
And i pass 2000 posts.......of completely inane drivel........ :cool:
Gavv8
« Reply #76 on: 27 April 2013, 15:27 »
Ok...new rear discs/pads/bearings today...a swine of a job due to seized carrier bolts that was solved with my new best friends the Irwin extractor family, also fitted new top mounts and bearings and generally had a good poke around underneath to see if there is anything left after the harsh winter.. generally ok apart from a hole in the sill under the o/s/f around one of the rubber plugs so some welding is on the cards this summer, this seems to be the only serious rot on the sills but we'll see what happens when i get it on the ramps and get a proper diagnosis.
I also seem to have a leak from the gearbox where the shifter goes in at the top, topped up the fluid and it doesn't appear to have lost much but it looks like another job to add to the list.. :sad:.
I also noticed that GSF were doing a discount on brake parts so snapped up a new set of front discs for £24 the pair.. :afro:.
Onwards and upwards.
Gavv8
« Reply #77 on: 21 May 2013, 14:27 »
Much work to be done this summer...small amount of welding..some paintwork..gearbox shifter leak.. and new rear beam bushes..
Change of plan as due to all of the above it will now be laid up long term.
« Last Edit: 01 June 2013, 23:59 by Gavv8 »
« Reply #78 on: 25 May 2013, 03:20 »
new pic looking sweet man. you got the mk3 so clean, as it should be! :)
Gavv8
« Reply #79 on: 25 May 2013, 09:38 »
Cheers buddy! :smiley:
